20 Most Recent Nuova Simonelli MDX Electric Grinder Questions & Answers
2answers
Nuova MDX espresso grinder wiring help
Fixed it Myself
Red wire --> Cap1
White wire --> Cap2
Blue wire --> PWR Switch
Brown wire ---> Thermal Protection Switch
9/24/2021 9:45:42 PM • Nuova Simonelli... • Answered on Sep 24, 2021
I can hear the grinder
Remove the bean hopper and vac out all beans, then remove black cover, then 3 phillips screws, and top part of burrs should come off. Clean our chamber then reassemble. DO NOT TURN ON. Make sure middle nut in chamber spins freely, use fingers to turn, if not adjust setting to coarser, until it moves freely, then turn on grinder. All you have to do now is set your grind.
1/5/2011 12:51:03 AM • Nuova Simonelli... • Answered on Jan 05, 2011
What is the proper number setting for the grinder
There isn't one, because your grind depends on the bean you are using, the temperature and so on. The best thing you can do is clear the burr chamber of beans, then turn grinder clockwise until you can no longer turn the brass fitting in the middle, then turn counter-clockwise to about 4 numbers that will give you a nice starting point to setting your grind.
2/18/2010 6:21:36 PM • Nuova Simonelli... • Answered on Feb 18, 2010
How do I unscrew the bolt on top of my Nuova Simonelli coffee grinder burr? It has a spining disc that turns if i try to unscrew it, thanks, Philip
Hello Philip When you unscrew the burr bolts usually you do it to replace them. The lower burr holder plate must be stopped from spinning with 1 screwdriver put in the exit hole of the coffee and touching the burr holder flaps (usually they are 3 flaps). The screwdriver will block and you can freely work.
11/24/2023 5:22:39 PM • Nuova Simonelli... • Answered on Nov 24, 2023
Machine not filling with water and tripping thermal fuse, how to fix??
It sounds like the issue may be related to the water flow, as you mentioned that the machine is not filling with enough water. This could be caused by a malfunctioning water solenoid, pump, or manual water fill valve. To troubleshoot the issue, you may want to try the following steps:
  1. Check the water supply: Make sure that the water supply to the machine is turned on and that there are no kinks or blockages in the water line.
  2. Check the water filter: Check the water filter to make sure it is not clogged or needs to be replaced.
  3. Check the water solenoid: If the water solenoid is not functioning properly, it may not be allowing enough water to enter the machine. Check to make sure that the water solenoid is receiving power and that it is opening and closing properly.
  4. Check the pump: The pump is responsible for pumping water through the machine, so if it is not working correctly, this could be causing the issue. Check to make sure that the pump is receiving power and that it is pumping water through the machine.
  5. Check the manual water fill valve: If the manual water fill valve is not working, this could be preventing water from entering the machine. Check to make sure that the valve is open and that water is able to flow through it.
If none of these steps resolve the issue, it may be best to contact a professional technician to diagnose and repair the machine.
4/11/2023 12:25:12 PM • Nuova Simonelli... • Answered on Apr 11, 2023
I have a Nuova Simonelli Mac Cup 2 Group. 1 group works fine. 2nd ... NO WATER gets to the group head.
It sounds like you may have a clog in the water line or the tubing that leads from the water tank to the 2nd group head of your coffee machine. To address this issue, you can try the following steps:
1. Disconnect the tubing from the group head and the water tank.
2. Flush the tubing with hot water to remove any buildup or debris.
3. Check the inlet and outlet holes on the group head to make sure they are not clogged or obstructed.
4. Reattach the tubing to the group head and the water tank, making sure it is securely connected.
5. Test the water flow to see if it is now flowing properly.
If the water still does not flow after following these steps, you may need to disassemble the group head and inspect it for any further blockages or damage. If you are not familiar with this type of maintenance, it is recommended to seek assistance from a professional.
2/11/2023 4:47:29 AM • Nuova Simonelli... • Answered on Feb 11, 2023
I have Nuova Simonelli Appia espresso machine. When running it off the generator after a while it will shut off completely and loose all power then after 5 to 10 minutes it will come back on?
You can't run a coffee machine off a generator, it draws too many amps, and needs stable voltage.
8/31/2022 4:37:29 AM • Nuova Simonelli... • Answered on Aug 31, 2022
Nuova simonelli mia, electric diagram
They have Service Manuals, but your 'Mia' machine doesn't exist, perhaps it isn't on the US market. https://www.simonelliusa.com/products/all-equipment-documents-archive.asp Service Manual for a Musica model https://www.google.com/search?q=Nuova+Simonelli+Mia+wiring+diagram ..
9/24/2021 10:09:04 PM • Nuova Simonelli... • Answered on Sep 24, 2021
I have a Nuova Simonelli Aurelia Espresso Machine and I believe I tripped the fuse. Where is the fuse located on this machine?
open the right side panel and you can see the heater of the tank, with that heater, there is a thermal cut out switch that you can reset by pushing the red button.
1/24/2021 1:42:05 AM • Nuova Simonelli... • Answered on Jan 24, 2021
I got a Nuova Simonelli Oscar, it has a few years and has been maintained. However lately, the water pump activates by itself very often.
After I press "turn on" button heat light just flashes for a second then pump starts. Without any delay immediately after pump starts I can see all water running through 3-way solenoid valve to the drip-tray. It runs without interruption approximately 90 seconds until safety timer turns the pump off and "empty tank" light is turning on. Shut it down, turn it on and everything happens again.
4/18/2020 5:40:33 PM • Nuova Simonelli... • Answered on Apr 18, 2020
My nuova simonelli commercial machine wont stop dispensing water..help please
is it in the group or in the hot water dispenser? check if solenoid open.
9/8/2019 9:15:16 AM • Nuova Simonelli... • Answered on Sep 08, 2019
The machine always heating up and RED color for the display. In just only a maximum of 5 cups heating up again. if I don't reset to turn off and on again the machine is not working any more thanks.
Most domestic coffee machines only have a small heater tank. I would suggest that after 5 cups, the tank cannot retain enough heat as the cold water from the supply has refilled it and it has to reheat again. If it wasn't doing this before, you may have to contact a service Company.
6/16/2019 7:20:01 AM • Nuova Simonelli... • Answered on Jun 16, 2019
I have a nuova simonelli premier maxi and when i pull a shot water gets into the boiler and eventually the boiler gets too full what is wrong
Is it constantly filling even the machine not in use, or just when your brewing, the pump keeps on running? If it is constantly filling that means you filling solenoid valve are mechanically open already. if only when brewing, check you water level sensors.
6/11/2019 11:39:16 AM • Nuova Simonelli... • Answered on Jun 11, 2019
Water level in site glass
what do you see? normally should be half level only.
6/11/2019 9:02:09 AM • Nuova Simonelli... • Answered on Jun 11, 2019
We have a Nuova Simonelli Aurelia 2-head and one head shoots espresso grounds in the shot halfway through. We tried replacing the gasket but still does it.
is it leaking on the side of the portafilter or what you mean is the dose is short? if dose is short, you can calibrate by pressing the fifth button on that group about 5 sec. then it will blink. prepare you grind in the portafilter then put it in the group. brew with the appropriate button the manually stop at the right level or quantity in the cup. you can do this with all the doses you require. Now by pressing the fifth button again 5 sec. you can exit programming mode.
4/2/2019 6:49:21 AM • Nuova Simonelli... • Answered on Apr 02, 2019
Nuova simonelli appia2 , steam fine hot water fine but when I make a coffee , it be a cold coffee ?
if you remove the drain tray, there is another plastic cover with screws. remove that too. inside on the right side you will see a black box with a yellow round cap. peel the cap off then you can see a screw. there is also a label that describe the direction of rotation. adjust it there. this is to adjust the pressure of steam. as your machine is increasing steam pressure, it also increases the water temp.
4/2/2019 6:43:53 AM • Nuova Simonelli... • Answered on Apr 02, 2019
Hello, I have a nuova simonelli aurelia 2 group ( heads) . Steam and hot water from the groups is good but on the water dispenser water is coming in a very lower temperature. Is there any trick to fix this by my self? Thanks in advance.
yes, just behind the tap there is a mixing valve that you can adjust to mix steam and water. this steam is the one making your water hot. open the top cover behind the tap and follow the pipe. there you will see it and adjust.
4/2/2019 6:39:21 AM • Nuova Simonelli... • Answered on Apr 02, 2019
Nuova Simonelli MDX Electric Grinder Logo
11 questions posted
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
ADMIN Andrew
ADMIN Andrew
Gary F
Gary F
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Nuova Simonelli Coffee Makers & Espresso...
  • Nuova Simonelli Coffee Makers & Espresso...
Most Popular Question
nuova mdx espresso grinder wiring help
  • Coffee Makers & Espresso Machines
