20 Most Recent
Mr. Heater Suspended Garage Heater Questions & Answers
My honeywell gas suspended garage heater will not
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
My mr. Heater lights only stays lit for about 3 minutes and then it goes out
I had this same problem with my heater. I cleaned the propane tube where the flame comes out (after it’s off and cooled down) with a Qtip and some alcohol. After removing some cotton, it will fit all the way down to the end of the tube. Repeat until it comes out clean and stays lit. I had to repeat with 91% rubbing alcohol and more Qtips, and most of the cotton removed.
How do i disable the oxygen sensor on a mr buddy heater
The responses so far I don't believe are answering the question. Instead, they are mentioning potential problems not related to the question.
The Mr Buddy propane heater has a sensor which detects the amount of oxygen/fresh air in the area being heated. If the amount of fresh air/oxygen is too low, the sensor will shut off the propane flow to the pilot light and burner. The question is asking, how to bypass/disable the sensor.
