20 Most Recent Electrolux 37 in. Designer Series E36IC75FSS Electric Cooktop Questions & Answers
Power button problem
Without being there to troubleshoot further, the first thing I'd recommend is checking the breaker. It'll most likely be in the breaker panel outside the house... in the BIG panel. This is a 240 Volt unit, so what you'll be looking for is a "dual" breaker. They'll be connected together.
I'll tell you what... here's the easy way to do it. Simply turn off, then turn on all the breakers in the big breaker box outside. Make sure you have all the computers turned off first, though. You might have to reset a few clocks, but that's OK. I'd bet this gets you cooking again. If not, post back.
1/7/2016 6:40:58 PM • Electrolux 37... • Answered on Jan 07, 2016
2answers
I have an elecrolux E36EC70FSS2. The strip of stainless trim between the controls and the burner has come unglued and bows up when the lower elements are on. What adhesive do I need to resecure it. I
there are Solder cool, they sell in any auto parts, is speciall Glue for seal any things. Solder in Cool. contain 2 parts a+b Buy it and fix it.God bless you
9/25/2012 6:06:24 PM • Electrolux 37... • Answered on Sep 25, 2012
Electrolux Induction Cooktop E36IC75FSS Error Code 41
Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
8/29/2012 7:17:59 PM • Electrolux 37... • Answered on Aug 29, 2012
0answers
2answers
I have an induction cooktop
hi i could not find this model in the uk european models but i do no that e90 codes usually relate to configuration problems possibly between user interface and powerboard . solutions are usually expensive. just check that bridging connections at the terminal block are correctly in place.
1/11/2012 11:19:35 PM • Electrolux 37... • Answered on Jan 11, 2012
What does the 'E73' error
1. Make sure that you have placed a metal container on the device which is compatible with the Induction cooker. 2. Try reseting the breaker, the instruction are available in the user manual.
Try these. I will be there to help you!
6/4/2010 6:01:15 PM • Electrolux 37... • Answered on Jun 04, 2010
Electrolux Induction Cooktop Kite C-561 3611 00 Rev B- All the lights are turned on
We aren't Electrolux, we are FixYa dot com, and you appear to have fixed it. Resetting the board would simply involve cutting the power to it. Induction cooktops are a relatively new innovation to the home markets are in general, all Induction cooktops fail due to failing electrical components. I have a 50 year career in catering, and 10 years with induction units. Even the catering quality units with a single hob that cost $1,800 fail in 18 months to 2 years. Contact Electrolux direct and ask if they can find the failed component and repair the board. https://www.google.com/search?q=%E2%80%8BContact+Electrolux ..
7/25/2023 2:18:48 PM • Electrolux... • Answered on Jul 25, 2023
I have an Electrolux cooktop model # EW36CC52GS. Changed a burner. There are 2 identical connectors on the terminal board which one do I plug the top back into, I didn't see second connection.
there should be identifier letters on the terminal board use a magnifier follow the lines that come from each connection on the board.
11/29/2019 3:54:30 AM • Electrolux... • Answered on Nov 29, 2019
My Electrolux induction hob showing error massage E9, Advice please
https://www.support.emea.electrolux.com/en-uk/Hot/Hob/Hob_displays_error_message_E9
11/28/2018 3:44:53 PM • Electrolux... • Answered on Nov 28, 2018
Knobs for Electrolux gas hob?
Searspartsdirect.com has parts lists and diagrams if you have your model #.
11/8/2018 3:25:39 AM • Electrolux... • Answered on Nov 08, 2018
Are the installation dimensions the same between Electrolux Icon 36” induction cooktop E36ic801ss1 and this years model E36ic80Qss?
You would have to compare owners manuals and installation instructions of both models.
10/21/2018 7:18:45 PM • Electrolux... • Answered on Oct 21, 2018
My 36” Electrolux glass cooktop just stopped working. Was boiling eggs & noticed it wasn’t working so checked breaker box. I flipped breaker off for 30 sec & turned on to no avail.
The breaker can still be the problem. The way to prove it is to measure the voltage at the wall plug where the cook top is plugged into the wall. Unplug the cook top and look at the pattern the plug contacts make. Should look something like a Y. Using a volt meter set on AC and 240 volts put one lead in the bottom leg of the Y and the other lead on one of the other leg contact. You should read 120 volts on each leg. If one leg has no voltage, replace the breaker in the panel. If the voltage is present on both legs of the plug then the breaker is good and the problem lies in the electronics of the cook top or perhaps a burned out heating element.
5/27/2018 2:57:28 PM • Electrolux... • Answered on May 27, 2018
Model #EW30ES65GSD ELECTROLUX slide-in range, electric How to get to the elements for replacement?
Unplug the range then you need to take the side panel off and there will be a slide out tray with the lower element in it. Disconnect the old element and reinstall the new unit in reverse order. Hope this helps
3/26/2018 1:42:58 AM • Electrolux... • Answered on Mar 26, 2018
ERRORS on Electrolux Icon 30'' Induction Cooktop
Call Electrolux or go to their web site and explain the problem there tech department will be able to tell you if you need a service call or can fix yourself.
10/3/2017 3:26:59 PM • Electrolux... • Answered on Oct 03, 2017
My Electrolux induction range works perfectly except when the cooktop is on and the oven is on. It pops the breaker. Individually they're fine. The error message is E36. Help!
you are drawing too many amp. Each appliance should be on always unplug electricity before working on any electrical appliance its own breaker
10/2/2017 12:52:10 PM • Electrolux... • Answered on Oct 02, 2017
Finish on electrolux cooktop is comiming off after minimal use. Is that normal.
No it is not normal, I do however assume that you removed all protective covers before use. You will need to contact the supplier of unit or elecrolux for replacement / repair under warrenty.
5/6/2017 4:57:11 PM • Electrolux... • Answered on May 06, 2017
Electrolux 37 in. Designer Series E36IC75FSS Electric Cooktop Logo
11 questions posted
Top Electrolux Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Cooktops
  • Electrolux Cooktops
Most Popular Question
elecrolux e36ec70fss2 strip stainless
  • Cooktops
