20 Most Recent Kenwood KAC-X1R Car Audio Amplifier Questions & Answers
Kenwood excelon x1r
need more info.
11/15/2013 4:13:06 AM • Kenwood KAC-X1R... • Answered on Nov 15, 2013
Amp is not turning on at all. The capacitor I have
this might sound dumb but check the ground on the amp make sure its getting good connection to the frame
5/21/2011 7:55:44 AM • Kenwood KAC-X1R... • Answered on May 21, 2011
When I turn up the volume the amp shuts off and displays an E-03
do you have your subs wired down to 1 ohm? The reviews on this amp is not very good, a lot of people said they had a lot of problems with this amp, a lot of blown fuses and cant take a 1 ohm load
5/12/2010 2:41:14 AM • Kenwood KAC-X1R... • Answered on May 12, 2010
HOLA, ME GUSTARIA SABER COMO CONECTO EN BRIDGE MI
Es un monoblock amplifier, esto significa que el amplificador es de un solo canal, y este tipo de amplificador no se puede conectar en bridge.
8/16/2009 12:24:08 AM • Kenwood KAC-X1R... • Answered on Aug 16, 2009
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
6/23/2009 11:02:42 AM • Kenwood KAC-X1R... • Answered on Jun 23, 2009
How can i hook up a L7 solo BARIC sub, up with a
Use The Little Adaptee [ 4pin ] Sold Seperatly
And You Can hook Your 6x9's Directly to it that way.
6/14/2009 2:20:10 AM • Kenwood KAC-X1R... • Answered on Jun 14, 2009
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
11/22/2008 1:32:28 PM • Kenwood KAC-X1R... • Answered on Nov 22, 2008
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
I have 2 mtx 12"woofers (8ohms each wired parallel to get to 4ohms) which Kenwood amp would be best to use: kac-7252 or kac-9104d?
The Kenwood KAC-7252 and KAC-9104D are both great amps, but they have different strengths and weaknesses. The KAC-7252 is a 5-channel amp that can output 75 watts per channel at 4 ohms. It also has a built-in crossover and time alignment, which can be helpful for getting the most out of your woofers. The KAC-9104D is a 4-channel amp that can output 100 watts per channel at 4 ohms. It also has a built-in subwoofer output, which can be used to power a separate subwoofer. If you are looking for an amp that can power all of your speakers, the KAC-7252 is a great option. It is also a good choice if you want an amp with built-in crossover and time alignment. However, if you are looking for an amp that can power a subwoofer, the KAC-9104D is a better choice. It is also a good choice if you want an amp with more power output. Ultimately, the best amp for you will depend on your specific needs and budget. If you are not sure which amp is right for you, it is always a good idea to consult with a professional car audio installer. Here is a more detailed comparison of the two amps: Kenwood KAC-7252
  • 5-channel amp
  • 75 watts per channel at 4 ohms
  • Built-in crossover and time alignment
  • MSRP: $399
Kenwood KAC-9104D
  • 4-channel amp
  • 100 watts per channel at 4 ohms
  • Built-in subwoofer output
  • MSRP: $499
I hope this helps!
12/13/2023 2:44:37 PM • Kenwood Car... • Answered on Dec 13, 2023
Kenwood KAC-X1R Car Audio Amplifier Logo
Popular Tags
16 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
kenwood excelon x1r
  • Car Audio & Video
