20 Most Recent Amana PTC153B50AJ Electric Heat Air Conditioner Questions & Answers
I'm seeing a master switch on the control board, try a reset there. But, sounds like a bad element. You need to test continuity through your heater components. When testing a component unhook wires first, as they will still have continuity even if bad with wires attached.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Amana... | Answered on Jun 04, 2017
Do you think you have a heat pump outside ?If so then I would call the installer back and show me how to operate the control.They should have did that when it was install.
Amana... | Answered on Aug 02, 2012
maybe u sure the pan is clean
Amana... | Answered on Jun 20, 2009
1. copressure not working.
2 check spare parts of a/c.
3 wiring
Amana... | Answered on Mar 17, 2008
FAULTS ARE STORED WITHIN THE CIRCUIT BOARDS MEMORIE TRY UNPLUGGING IT FOR 2 MINUTES AND PLUGGING IT BACK IN
Amana... | Answered on Feb 11, 2008
Before the replacement of board please check the fallowing:
- Check for loose terminals and re tight.
- Check compressor terminal post if terminal clips are tight.
- Check compressor resistance and terminal to ground resistance. And check your compressor is not stuck up.
- Check indoor and outdoor blower motor if not stuck up by rotating it with your finger, if it rotates freely then its ok.
- Check the resistance of both indoor and outdoor fan motor resistance and line to ground.
- Check your voltage supply if normal.
- Check the compressor and blower motor capacitor if good.
- Check the unit supply wire if not discolored.
- Check the terminal of your circuit breaker if tight.
If all of the above are ok then it is safe to replace your unit with new board
May be poor contact of the said relay may cause the blowing of your board. Volatage fluctuations is also the suspect or damage solder of the board due to heat.
Amana... | Answered on Jan 22, 2008
possible that this is normal to expel residual moisture gathered during normal operation.
Amana... | Answered on Nov 29, 2007
It will be one of three issues. Blower motor is bad , capicator, or the control board. Easy enough to check . Use an extension cord , cut off the female end and strip it . You should have a black and white wire. Find the wires leading to the motor take the black and white off the control board conect black to black and white to white. Plug it in an outlet if the motor runs its the control board . If not its a bad motor or capicator. But caps rarely go bad in this use . So most likely motor . Not a hard job , but not eady if you dont have the right tools. Do not bang on the shaft with a hammer . You must use a special tool for pulling shafts.
Amana Heating &... | Answered on Sep 30, 2018
It is not switching from cooling into heating. You probably need to have a service tech look at the unit. Sorry. It could be control board or stuck reversing valve.
Amana Heating &... | Answered on Sep 26, 2018
It could be the compressor, motor is shorted or grounded.
Goodman Industries has purchased Amana. So go to Goodman website for info. Without model number I cannot look up error code
Amana Heating &... | Answered on Sep 20, 2018
It could be the motor speed windings are bad for higher speed or switch/controller needs to be replaced
Amana Heating &... | Answered on Aug 22, 2018
Amana PTC153B50AJ Electric Heat Air Conditioner Logo
13 questions posted
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
amana ptc153a50ad electric heater
  • Heating & Cooling
