20 Most Recent
Fellowes Powershred C-320C Shredder Questions & Answers
Won't turn on
Make sure that the shredder component is seated in the correct way. There usually is a button on the bottom of the shredder component, that will not allow the shredder to run UNLESS it is seated correctly. DO NOT PUT YOUR HANDS NEAR THE BLADES
7/17/2014 6:20:44 PM •
Fellowes...
Answered
on Jul 17, 2014
The shredder was jammed and
Before giving up..
I'd suggest that you first UNPLUG THE SHREDDER. Then carefully inspect inside the paper input chute. There should be one or more small slots with spring contacts inside them. You may have jammed one or more of them permanently into the on position while clearing your paper jam. Especially if the jam was caused by and adhesive backed material in the shredder. If you see one of them jammed just manually clear it and try again. I doubt that the contacts have fused. That requires high currents. These sensors use very low current to make or break the contact.
6/19/2014 4:11:39 PM •
Fellowes...
Answered
on Jun 19, 2014
Need part # to replace blades
There are at least 4 versions for this model that take different parts. This model was dis-continued quite awhile ago and i doubt that parts are available anymore. Also, there are 2 cutting cylinders in the machine and they are different lengths. Usually would replace entire cutting head unit instead of just 1 cylinder. But you can call fellowes at 800-955-0959 and see whats still available.
8/19/2013 8:45:06 PM •
Fellowes...
Answered
on Aug 19, 2013
It makes a loud screeching
Sqirt shredder oil on a piece of paper that you want to shred & feed it through your shredder. Do not soak the paper a little is all you need.
1/14/2011 5:24:37 PM •
Fellowes...
Answered
on Jan 14, 2011
What is the fiscal size of Fellowes shredder?
Question edited for clarity, spelling of 'Fellowes'.
I don't think 'fiscal' means what you think it means?
fis·cal
/?fisk(?)l/
adjective
relating to government revenue, especially taxes.
"monetary and fiscal policy"
Fellows does all sizes of shredders up to Office Quality machines that will also Crosscut shred credit cards and CDs.
https://www.google.com/search?q=Fellowes+shredders
