20 Most Recent
Frymaster Dean MJ45 Deep Fryer Questions & Answers
Deep fryer, once reaching desired
Have you replaced the high limit? That's what I would try next... When the thermosat doesn't fix it, it's usually the high limit, but you can't tell until you replace the thermostat first... Another way to get just alittle bit more of your dollar too.... If you need pricing, please call us at 888-542-5959 or email us at
[email protected] Our website is
www.restaurantequipmentinc.com
Thanks, Susan REO
How to clean blocked pilot orfice
One time this happened to me on a gas stove. I used an electric drill with drill bit to clean it out. It will only work if the line is straight, no bends in the line.
Can anybody tell me what's wrong with this? Any suggestions please and thank you.
The burner or the burner venturi is clogged. The burners are held in place with 2 bolts at the top and you need a 1/2 inch wrench. Remove the bolts and lift the burners off the brass orifices. Make sure all the holes are clear. If they are clogged they need to be drilled out. You should not have yellow in the flames in the burner tube.... kinda looks like the are sooting. This causes flames to come out the bottom of the burners.
Pilot light lights but is a low flame
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
