FixYa.com
La Pavoni Club Combo Duet PA-1315 Espresso Machine
All Products > La Pavoni > Coffee and Espresso Makers
Problems with La Pavoni Club Combo Duet PA-1315 Espresso Machine?
Search inside La Pavoni Club Combo Duet PA-1315... Knowledgebase
Troubleshooting and Support
Solved Problems for La Pavoni Club Combo Duet PA-1315 Espresso Machine RSS Feed Post a New Problem
Where can I buy the seals for the inside...
Where can I buy the seals for the inside of the coffee maker. I fabracated one but it doesn't do the job. Everywhere I...
1 Solution
What should be used to clean the inside of...
What should be used to clean the inside of an automatic coffee maker?
2 Solutions
What if my coffee tastes bad?
1 Solution
Coffee does not brew
Coffee Maker has worked fine for a couple of months. Now, put the ground coffee in, put the water in, turn on, nothing...
1 Solution
TCM400 will not perk
1 Solution
Leaking around the group
My ECM Giotto is 3 years old and recently started leakin. I called the place where I bought it and they suggested it...
1 Solution
electrical cord for coffee urn...
Hi, I am missing the electric cord to West Bend 58030 Coffee Maker. Where could I find a replacement cord? Thanks,...
2 Solutions
View All
Unsolved Support Problems
Unsolved Problems for La Pavoni Club Combo Duet PA-1315 Espresso Machine RSS Feed Post a New Problem
Push buttons gone bad!
Hi I have a Pavoni Duet PA1315, and it worked great until the push buttons failed. The one that turns it on/off is not...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeEspresso Machine
Operation SourceElectric
Max. Power1150 Watts
Max. Pump Pressure16 Bar
Technical Features
Cup FillerSingle
Built-in GrinderWith Built-in Grinder
Cup Warming SurfaceWith Cup Warming Surface
Water Source
Water Tank Size64 oz.
Water SourceRemovable
Dimensions
Depth10 in.
Height12 in.
Width13 in.
Weight24 oz.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
