This space heater turns on with a beep and red numbers to indicate the temp of the room, but doesn't...
(More)
This space heater turns on with a beep and red numbers to indicate the temp of the room, but doesn't click on the heat even though the dial turns the set temp above the room temp. The timer settings work, too, but nothing happens. It was working earlier, and later in the day, when plugged in again, had no heat blowing.
http://johnstonesupply9.com/TechDocs/Goodman/Furnaces/GMV9%20Variable%202-Stage%20Upflow%20Gas%20Furnace/GMV9%20Service%20Man.pdf After giving up on...
written by lallen_rgmv4
Traditional water heaters use a storage tank to hol... Read More
Traditional water heaters use a storage tank to hold heated water until it is needed. They typically run off of natural gas, but electric and propane heaters are also common. In addition, tank less water heaters are available. They operate by routing water to where it needs to be instead of storing
