Daewoo Air Conditioner
Problems with Daewoo Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Daewoo (DWC-056CL) Air Conditioner
Troubleshooting and Support
Solved Problems for Daewoo Air Conditioner RSS Feed
Click here to get instant support from our best Experts!
View More Results for Daewoo Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Daewoo Air Conditioner RSS Feed
Answer
where are the drain plugs for a/c model number dwc-056cl
Answer
wont go below 71 degrees . we were moving. We plugged it into a non 115 amp outlet for 4 hours., and... (More)
Answer
Daewoo a/c window unit only one year old...not blowing cold air. HELP! Would like to fix it myself... (More)
Answer
My daweoo 055rl is leaking a lot of water. Is it broken?
Answer
Water in base pan of my daewoo dwc o55rl . I am wondering if a couple of holes at the base of the... (More)
Answer
daewoo 056cl it leaks a lot of water. It is collecting and leaking from the bottom somewhere.
Find a Manual
Daewoo Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
Tips & How To Guides for the Daewoo Air Conditioner
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
A Tip to Remember when Electrical troubleshooting
If you're troubleshooting HVAC electrical problems 230 volt single phase ac The Common wire or circuit on an A/C or heat pump never has a run... written by blvl777
Air Conditioner Ice Air Conditioner Problem
If you are experiencing the problems caused when your air conditioner becomes a solid block of ice then you need to figure out the real reason why it... written by heatman101
Air Electronic Cleaner - Electronic Whole House Air Cleaner
An electronic air cleaner can improve the indoor air quality as well as the performance of your heating and air conditioning system. That?s why many... written by heatman101
Central Air Conditioning or Window Air Conditioner
Many people look into installing air conditioning in their home every year. There are many options to consider when it comes time to make that... written by heatman101
Any time you disconnect any wires from anything.
Any time you diconnect any wires from anything always mark the wires with a piece of masking tape and write where you removed it from, especially if... written by blvl777
How to store you air conditioner for the winter?
Make sure that you tip the A/C unit to remove water that has condensed in it. If water is left in the system over the winter/spring, it can rust out... written by perrault
how to make your heat pump more efficent
you should first change your filter ,this type of unit relies on good air flowFind a HVAC supply house in your area (they all say there not open to... written by bwood348
Checking out a Air Conditioner Compressor and compressor problems
Checking out a air conditioner compressor and compressor problems FIRST DISCONNECT ALL ELECTRICAL POWER Ohm the windings C to R = example 1.2 C to S =... written by blvl777
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Daewoo Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Ratings for the
Find a Warranty
Specifications for Daewoo Air Conditioner
Key Features
Dehumidifier
With Dehumidifier Functionality
Cooling Capacity
5340 BTU/hr
Energy Efficiency Rating
10.2 EER
Other Features
Filter
Reusable
Dimensions
Depth
15.4 in.
Height
17.4 in.
Width
19.2 in.
Electrical Requirements
Voltage
115
Cooling Watts
525
Daewoo Contact Information
Main support number800-323-9668
Support FAX973-384-9250
Email supportservice@e-daewoo.com
Describe your problem:
Top Air Conditioner Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
