Troubleshooting & Support
Hot Topics:
- error code 66
- 57732
- thermal sensor
- power light tv...
- green light
- lamp light
- pc dvi
- air flow...
- Ballast
- yellow lamp...
- screen
- removing screen
- clicking
- tv reset
- error codes
- turn tv green...
- air flow...
- 57731
- blinking green...
- power light...
- bright white
- turns
- lamp light...
- message lamp
- video
- shut down
- error code
- red light
- tv
- settings
- View All »
Problems & Solutions
My T.V. is making a
Tries tv and cables or satalites services boxes unplug,replug it back like about an hour later for tv to do a whole tv set resetting itself...
Hi! We have a Mitsubishi
Hi Julie, Restore the unit first to "factory settings" by following the steps below. > Enter the service adjustment...
I am trying to replace
The thermal sensor is located on the lamp cartridge housing. here take a look at this link...
WD57732 purchased 12/06 and has worked fine.
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2...
blinking green light
Is it time to replace the projection lamp? Check your owners manual, it will assist you in the replacement process. If you don't have...
replace bulb in existing cartridge
You need to wear rubber Gloves you do not want your fringer prints left on Lamp, install it the same way old one was hooked up only 2 wires...
Mits WD52631 model- television turns itself off
Lamp door senser maybe defective.
replaced lamp on WD57731. green light turns on
Please put back lamp cover, the last plastic grille that were removed to replace lamp in TV. TV sense that lamp cover is not either put back...
error / problem message
these are on mitsubishi's recall list you need to get in touch with mitsubishi and have them find a authorized servicer in your area to...
how do I remove the lamp door
there are 2 phillips head screws on the door remove them and the door comes off. Look up inside and you can see the lamp it has either 2 or...
the screen is delaminating at the bottom. can the
Yes the screen can be replaced but is very expensive.There is also a service bulletin on this chassis for replacing an overheat sensor...
Getting a shadow where their are white areas
likely very dusty inside have a service shop do it, you can damage the optical unit if you do it wrong. Julio milleniumtvsvc@gmail.com
mitubishi WD-57732
I'm assuming that you already have the housing out of the TV. If not remove the lamp cover panel (two phillips screws), Locate and...
I have a wd 57732
Hi! It's perfectly safe! Just be sure to always wait an hour or preferebly more before doing this, and unplug the tv! On a DLP tv such...
mitsubishi dlp tv model number wd57732 purchased...
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part #...
Unsolved Problems
My Mitsubishi WE-57732 won't come on although
My Mitsubishi WE-57732 won't come on although we get audio, and then makes a clicking noise and continues even after...
purchased 2 new lamps tried both of them sound
purchased 2 new lamps tried both of them sound comes on no picture turns off after about 30 seconds have replaced...
Mitsubishi WD-57732 has audio and black and white
Mitsubishi WD-57732 has audio and black and white vertical lines?
dark pic & takes a
dark pic & takes a while to cut on
I need to Replace my
I need to Replace my Mitsubishi Screen WD57732 Where can I get one?? Randall 407-383-6045
my mit model wd57732 has
my mit model wd57732 has a blinking yellow light on the front and the tv will not turn on. is this a bulb problem.
I have a Y 65
I have a Y 65 mitsubishi tv that has white vertical ines about one fouth way down on top. Can u help? Thanks Rita
The lamp is a month old, I replaced the Ballast.
The lamp is a month old, I replaced the Ballast. TV has sound but no picture & turns itself off after about 30...
Upload a manual for Mitsubishi WD-57732 Television
What's your problem?
Fix-O-Meter
12,020
12,020 people have viewed this product
- 122 people asked about this product.
- 42 people found solutions for this product.
- 5 people have added this product.
Common...
Solution for...
Sony TV Error...
