I have a Samsung blu ray disc player bd-p1200. I have accidentally changed the 1080i to 1080p and I...
(More)
I have a Samsung blu ray disc player bd-p1200. I have accidentally changed the 1080i to 1080p and I can't read the tv screen to change it back. What do I do?
the remote doesn't worked. Ie worked through all of the trouble shooting tips, each one several...
(More)
the remote doesn't worked. Ie worked through all of the trouble shooting tips, each one several times. Our tv is a Zenith LCD.
how come my bd-p1400 wont play my blue ray discs? i already have the firmware 2.0 and cleaned the...
(More)
how come my bd-p1400 wont play my blue ray discs? i already have the firmware 2.0 and cleaned the lens.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
Specifications for Samsung BD-P1200 Blu-Ray Disc Player
Key Features
DVD Type
Blu-Ray Disc Player
Number of Discs
Progressive Scan
With Progressive Scan
Playable Disk Types
DVD-RW · CD-R · CD-RW · DVD-R · DVD+R · DVD+RW · DVD-VR · DVD Video · CD (Audio) · DVD-RAM · BD-RE · Blu-ray
Playable File Formats
MP3 · WMA · JPEG · MPEG2
Other Features
Exterior Color
Black
Dimensions
Depth
12.8 in.
Height
3.1 in.
Width
16.9 in.
Weight
9.3 lb.
Warranty
Warranty
90 Days
Convenience
Remote Control
Standard
Record And Play Fetaures
Playlist Playback
OSD
Yes: English
Parental Control
Yes
Resume Function
10 Bookmarks
Video
TV Resolutions
480p · 480i
Picture Control
Zoom · Sharpness
Video Output System
NTSC
Video Upconversion
1080i (HDTV) · 720p (HDTV) · 1080p (HDTV)
Audio
Surround Sound
DTS (Digital out only) · Dolby Digital (Digital out only)
Dynamic Range
100 dB (DVD)
Audio S/N Ratio
110 dB
Connections
Outputs
Composite x 1, S-Video x 1, Component x 1, HDMI x 1, Analog Audio x 1, Analog Surround x 1, Digital Audio Coaxial x 1, Digital Audio Optical x 1, RJ-45
