how do i take off the progressive scan after i enabled it and now my screen is un recognizable. i...
(More)
how do i take off the progressive scan after i enabled it and now my screen is un recognizable. i cant see the set up screen at all its wiggleing like crazy i want to change it back. please help
My dvd player is starting to freeze up while playing a dvd. Is there anything I can do to correct...
(More)
My dvd player is starting to freeze up while playing a dvd. Is there anything I can do to correct this problem?
i was putting in code for new remote when the screen started flicking vertically and does'nt stop....
(More)
i was putting in code for new remote when the screen started flicking vertically and does'nt stop. it does this with or without the disc in. The TV works fine on TV mode
I have hooked up by DVR using component cables to a Samsung LN32B360 tv and the picture when I view...
(More)
I have hooked up by DVR using component cables to a Samsung LN32B360 tv and the picture when I view dvd's is red. I have checked both the back of the dvd and the tv and each component cable is in the correct spot...what else can I do?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
