20 Most Recent
Krups FBC212 1600 Watts Toaster Oven with Convection Cooking Questions & Answers
On off button usually fais to respond to on
It could be a problem with the board as that on/off button is one complete unit with the board, digital display and buttons attached. If you want to fix it yourself get your model number (FBC212) and head over to 1800Parts.com to see if they have the board in stock. You can also call Krups directly and they will tell you a service station in your area. We are one of their national service stations but we are in New York.
I need to replace the
Normally this is quite simple two screws hold the element on. If its
warped the you could cut it out with a junior hacksaw. Try not to
breath in the dust from same. Its possible that you are interesnting in the
User Guide here, or contact the
Krups Service Appliance.
Hops helps.
My krups stop working while
Make sure you have AC at the wall-plug by plugging in another appliance there. If not, you may have a tripped GFI (Ground Fault Interrupter).
If power is there, a thermal fuse, now common in many 'hot' appliances, may have failed.
These are almost all made in China now and have proven very unreliable; you may just be another victim of this.
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
