FixYa.com
Nemox X79751250 Electric Burr Grinder
All Products > Nemox > Coffee Grinders
Problems with Nemox X79751250 Electric Burr Grinder?
Search inside Nemox X79751250 Electric Burr Grinder Knowledgebase
Troubleshooting and Support
Solved Problems for Nemox X79751250 Electric Burr Grinder RSS Feed Post a New Problem
Nemox Lux Burr Grinder
I don't know if this is the same machine as the one in the listed on the FixYa page, but it looks like the one in the...
1 Solution
Why do the Nespresso machines operate at...
Why do the Nespresso machines operate at 19 bars of pressure, whereas all the others are at 15 bars?
1 Solution
Coffee is not flowing. What?s wrong?
1 Solution
What size paper filter should be used for...
What size paper filter should be used for the 4-cup drip coffee makers?
1 Solution
How to remove spray paint from iron?
I purchased a very cheap Coffee hand grinder. Someone had previously painted the wooden housing with a blue spray paint,...
1 Solution
not charging
hey. i have a 97 maxima. the alt. is good but is not charging the batt. belts are tight and fuses checked. the batt....
1 Solution
Do De?Longhi drip coffee makers feature...
Do De?Longhi drip coffee makers feature automatic shut-off?
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeElectric
Capacity5.29 oz.
Power150 Watt
Grinding MethodBurr Grinder
Dimensions
Depth7.09 in.
Height11.81 in.
Width3.74 in.
Weight3.97 lb.
Design
ControlsOn/Off Switch
MaterialStainless Steel Housing
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
