20 Most Recent KitchenAid KERS807SSS Electric Kitchen Range Questions & Answers
Most likely the extreme heat damaged the control board.
KitchenAid... | Answered on Nov 05, 2017
thermostat my be brokenit thinks its hot so it shuts the heat off....
KitchenAid... | Answered on Apr 21, 2014
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
KitchenAid... | Answered on Apr 16, 2014
Hi, samething happened to me today - did you get any solutions to this?
Let me know.
Thanks,
KitchenAid... | Answered on Oct 26, 2013
Had the same message on my display after spilling water on the cooktop. Obviously, the seal (rubber gasket) that prevents liquids getting inside the control area is not very good.
I replaced the Control (p/n: 10181439 / 9761799, 2 numbers, same part) and the flat cable between the touch keypad and the Control (9762781).
After turning the breaker back on, only had the message to set the clock.
KitchenAid... | Answered on May 21, 2012
Hello
The code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Call Kitchenaid helpline and thy will put ou through the process of getting a new sensor for your range
KitchenAid... | Answered on Aug 16, 2011
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
KitchenAid... | Answered on Jan 30, 2011
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^^&
KitchenAid... | Answered on Oct 01, 2010
This is a common issue and cannot be troubleshooted. The only way to fix this is to replace the temperature probe. The error will disappear and the range would start working fine.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
KitchenAid... | Answered on Sep 28, 2010
Glass tops can be very tricky.
Unless you know what your doing,
it might be wise to get a tech to do it.
There are elements/brackets/clips ect ect mounted to the underside of the top also.
Why do you need to remove it,??
KitchenAid... | Answered on Mar 04, 2010
Have you called the store?
This has been a problem with this EXACT model and KitchenAid has been ignoring it for a while. Many people online (when searched) has had countless problems and resulted in them taking it back and swapping it out for another (same brand) or another (different brand)
There is really nothing that can be done since it automatically beeps when you press a button. It's shocked!
I hope this helped
KitchenAid... | Answered on May 30, 2009
welll although oyour not running self clean, its possible you have a bad fuse. youll need to pull unit out and get behind to check the fuse for continutity, its a small (quarter sized thermostat) wioth 2 wired leading in and out of it, should have asticker with blue& white stripes on it.heres the part number if needed 9759242
KitchenAid... | Answered on Dec 30, 2008
KitchenAid KERS807SSS Electric Kitchen Range Logo
36 questions posted
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
kitcheaid kers 807 electric stove oven
  • Kitchen Ranges
