20 Most Recent
Whirlpool GU2700XTSS / GU2700XTSY Built-in Dishwasher Questions & Answers
The machine does not seem to rinse properly. We
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
4/6/2015 8:39:37 AM •
Whirlpool...
Answered
on Apr 06, 2015
Dish washer not cleaning dishes in top rack
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
1/14/2011 1:21:36 AM •
Whirlpool...
Answered
on Jan 14, 2011
Loud noise when washing, but
Everyone
expects their dishwasher will work correctly. They can become
nonchalant about it until one day it does not function. Sometimes the
dishwasher doesn't drain as expected. Most people immediately call the
plumber when their dishwasher doesn't work. There are several things
you can try at home before having to pay an expensive service fee.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Instructions And material Needed below.
Check
the basics. Make sure that the dishwasher has actually finish the
cycle. Your dishwasher will not drain until the end of the cycle. Many
things may have interrupted the cycle. Check circuit breaker and reset
it if appropriate. Also check the fuse. It is possible that you could
have tripped a circuit have way through the cycle. Make sure the door
is properly closed. Ensure you have chosen a cycle on the dishwasher.
It is amazing the problems children could accidentally cause, that are
easy fixes.
Remove
any excess food at the bottom of the dishwasher. The best way to do
this is with your hands. Large food particles can block from going into
the drain.This is also another extremely easy fix to make your
dishwasher to drain.
Check
to ensure that the hoses are still attached. Use your manual to find
where the hoses are. If they are not attached the owner's manual will
give you instructions on how the attach the hoses to your specific
dishwasher.
Attempt
to declog the line. Disconnect the hose from under your sink and check
to see if there are any clogs. Use a hanger or towels, remove the clog
from the hose.
Remove
the dishwasher basket. Again refer to your owner's manual for specific
instructions.Normally you will remove it with a screwdriver. Make sure
to work slowly. As you take the basket apart, you will be able to see
if it needs to be cleaned. If there is dirt or debris, you can clean
the parts with a rag or paper towel. After cleaning these parts, you
can replace the basket.
Call
a plumber. If the dishwasher is still not draining, the problems are a
little more complex to fix. It is advisable to call plumber to make
your dishwasher drain.
Good Luck and thanks for using fixya.
12/13/2010 9:11:49 PM •
Whirlpool...
Answered
on Dec 13, 2010
I have a whirlpool gold quiet partner iv model
That would mean that the brain has gone wacky....there is a box in the top of the door that runs the whole show there.. if that goes nothing happens...
You can find a replacement very easily...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
8/28/2010 11:45:38 PM •
Whirlpool...
Answered
on Aug 28, 2010
Dishwasher filling correctly?
john, the dishwasher has a timed fill, make sure you are using 3/8 inch line. If you are using 1/4 inch, that would be your problem. The fill should be just below the heating element. If you are using the 3/8 inch line, the next suspect would be the fill valve itself. Make sure nothing is kinked, Catriver.
8/24/2008 5:23:37 AM •
Whirlpool...
Answered
on Aug 24, 2008
Removal of filter module
the wash spray arm unscrews, then there are 5 torx 20 screws removing the top filter plate, under there is anohter 2 torx 15 screws allowing you acess to the chopper assy
4/9/2008 3:04:01 AM •
Whirlpool...
Answered
on Apr 09, 2008
