20 Most Recent Timex TMX1 Satellite Radio Receiver Questions & Answers
Hi, do you have the MiniTuner module in the radio? You need that in, and the antenna connected facing the SW horizon. Turn on to SATellite. Adjust antenna so that you can hear Channel 1 clearly. After you hear channel 1, the satellite will send a time signal. Then go to MENU, select Adjust time and pick your time zone and if you are on Daylight Savings time. Then, menu to exit out. Your satellite signal will keep the time updated when in Satellite mode.
I don't know if that will also set the regular clock too, or just only the time while in satellite mode. Let me know how you do with it.
Timex TMX1... | Answered on Aug 22, 2014
  • Hi, I can help.
  • The fact you are getting channels 1 and 2 says you are getting a signal. But it could still be the antenna.
  • When you go through the other channels (or attempt to) you should still see the channel and the brief description of that channel. Even if you have no service you can still scroll through the channels and if you stop on one and wait you will see the description, then after two seconds or so it will shown no signal, meaning no service. This is of course for those that have no service.
  • If you are getting this response then some things that can cause this are.
  1. No service.
  2. System needs a refresh.
  3. Antenna issue.
  4. Compatibility issue.
  • It would seem you had service and then it stopped out of no where.
  • You have refreshed it several times to no avail.
  • When you refreshed did you make sure to have your antenna outside, in the clear and facing the South? Making sure to leave it completely undisturbed until refreshed? Otherwise the refresh might not take.
  • The CNP 1000 antenna is exactly what you should be using. It is possible to get channel 1 and 2 and not the others from a bad antenna. Here is a place to get a new one should you wish to try that. http://store.xmfanstore.com/connectandplay.html
  • The radio is obviously compatible but sometimes a software update can become necessary. I don't think Timex offers any updates being this product is no longer made but I would suggest to try to contact them here http://www.timex.com/
  • A lot of people experience problems in one aspect or another with this particular product. Although while it works it is a fine radio.
  • If you have any comment please fel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Timex TMX1... | Answered on Aug 19, 2011
Timex might have it. Contact them.
Timex Audio... | Answered 2 days ago
Hello Glenn, I sent you the link to download the user manual of your Timex and follow the steps to configure the radio stations
Keep in mind that if the radio station is far away, you may have trouble tuning it
I hope you can solve your concern
Greetings Franco Dosil
Hola Glenn, te envio el link para que descargues el manual de usuario de tu Timex y sigas los pasos para poder configurar las estaciones de radio
Ten en cuenta que si la estacion de radio se encuentra lejos, podriastener dificultad para sintonizarla
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://cdn.ihomeaudio.com/media/product/files/T311IB57574_35.pdf
Timex Audio... | Answered on Jul 05, 2019
Hello Carey, you can find the alarm configuration form, which appears in the Quick Guide of your Timex clock radio T235Y.
I sent you the link, so you can download it
I hope you manage to schedule your Timex
Hola Carey, puedes encontrar la forma de configuracion de alarma, que aparece en la Guia Rapida de tu Timex clock radio T235Y.
Te envio el link, para que puedas descargarlo
Espero logres programar tu Timex
https://data2.manualslib.com/pdf4/80/7988/798701-timex/t235.pdf?4a0b39d025e7d16ec28f8e4574be1d11&take=binary
Timex Audio... | Answered on May 06, 2019
Press mode, then time and set
Timex Audio... | Answered on Jan 01, 2019
Since I don't know the model number I suggest you visit the Timex website and see if they have a free PDF of the instructions for your model.
Timex Audio... | Answered on Sep 17, 2018
I have never seen one but would guess you need to check if it 's face comes off or the entire clock comes off the cycles ome way
Timex Audio... | Answered on Jul 01, 2018
Timex TMX1 Satellite Radio Receiver Logo
Popular Tags
8 questions posted
Top Timex Audio Players & Recorders Experts
Janelle Schoonover
Janelle Schoonover
Steve Allison
Steve Allison
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Timex Audio Players & Recorders
Most Popular Question
set time date
  • Audio Players & Recorders
