20 Most Recent
Linksys WMP300N Pre-802.11n Wireless Adapter Questions & Answers
I just rebuilt my HP
Hi, Go to the Linksys site to get the correct driver package.
Thanks
Adam
please leave me some feedback
Unable to connect to linksys wrvs4000n router
If this is the first time you are connecting to a wireless router, consider using a wired Ethernet link rather than a Wi-Fi link. Your Ethernet connection will keep working even if you haven't finished configuring or accidentally break the Wi-Fi settings.
To setup your wireless network, perform the following steps:
1.Disconnect or turn off your broadband modem.
2.Connect the wireless router to the broadband modem through a network cable and then turn it on. You will have to plug in the network into a port called Internet, WAN or WLAN. The naming convention varies according to the manufacturer. The other ports on the router are for sending and receiving information to other devices on the wireless networks.
3.You can now connect to the internet via the router with the help of the wireless network card installed on your pc or laptop. The wireless card on the computer has to be turned on for it to recognize and connect to the wireless network.
You can check if the wireless network has been successfully setup by accessing the default router address via a web browser. You will be prompted for a username and password. After you have entered the default username and password, you will be directed to the routers configuration page. For your router, please use the address 192.168.1.1 Username "admin" and password "admin" (without the quotes).
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
I have wmp300-n card. I install card (software
i had that problem with another adapter, then i figured out that i was having problems with another pci adapter. so if you have another pci at the same time, try unplugging it and left the wmp300n alone, it worked for me
Connect another computer to wireless router
on any standard UNSECURED router, all you should have to do is click connect under "Network connections" in Control Panel. However, if the wireless router you would like to connect to is SECURED (password protected), you will just need to type in the password required in the connections when prompted.
This is assuming the other computer you are trying to add is wireless capable.
Encryptiing
Is your router from linksys also? How many wireless computers do you have? Note that if you encrypt your router, you need to make sure that each wireless computer gets the exact encryption keys you will use on the router. Usually the linksys router page can be accessed via http://192.168.1.1. Leave username blank, password is "admin". Go to Wireless >> Wireless Security. Select WEP-128 key. Enter in a passphrase and hit generate. Copy key #1 on a piece of paper (make sure it's 26 characters) and click apply. Next, go to each wireless computer and use encryption key#1 when you connect to the linksys router.
Linksys WMP300N Endless Bootup Loop
Disable or uninstall the Linksys software that manages and monitors the connection.
Use instead the Microsoft Windows Wireless configuration utility.
That's what I did and didn't get problem after.
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
I installed the software for
your Wifi is not Enable Yet,
you have to login into your Linksys and go to Wi-fi and Enable your Mac address for your Router..
WMP300N
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1144763512962
this page above mentione resolved your problem.
Download the driver.
Thanks
Sergio
Antenna extension
you can use another cable, with a connector between them, you can find these on ebay.
GoodLuck
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
LOW SIGNAL
Usually our CPU is on the floor or under the table, the common problem is signal, try to put your CPU on the table to roam a wider range. if still not much signal, just change your antenna with a better one.
Wmp300n auto-off
Is there the possibility that you could buy a more powerful device?
