20 Most Recent
Vestax PDX-2300 Turntable Questions & Answers
Vestax pdx 2000 loose to the touch deck
It is possible that the deck that feels loose is not properly secured to the turntable. You may want to try tightening the screws or bolts that hold the deck in place. If this does not fix the issue, there may be a problem with the bearings or the motor of the turntable. It is best to consult a technician or the manufacturer for further assistance.
Static sound
please bring an lubricant contact cleaner from radio shack near you and apply it in pots while you are moving it forward and back.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
