20 Most Recent
Stanton STR8-80 Turntable Questions & Answers
How to remote start stanton str8-80
A cable in your turntable , which you connect with your mixer and in the manual it says how to allocate the remote start to a fader / knob.
It's in the manual, except if your ain't able to it.....
G'day,
There is a little switch underneath the
That switch is the mains voltage selector and you friend just switched it the USA voltage setting! So it sent 230 volts to a device inside your deck which only takes 115 volts! If it doesn't come on when placed back on 230 volts, then if you are lucky a fuse might have blown! Check the one in the plug, then take the bottom off the turntable and see if you can see one inside. If your not lucky it might have destroyed parts of the power supply of the turntable, perhaps the transformer. And if your in a country that uses mains of 220 to 250 volts turning that switch to 115 is the self destruct with that power applied!!!
It won't turn on
they have internal fuses...you must open the bottom panel and replace fuses.
TurnTable left channel no signal
Somewhere in the jack or the plug you have a wire broken. You will just have to look for it. If you have a volt ohm meter, this will aid you in finding the broken conductor. When you find the bad connection, you will probably have to solder it back together.
The stanton T.80s do not have a port for grounding
These units are ground inside the decks. If you pop all the screws and remove the bottom, you'll notice where the RCA wires are hard wired into the unit, there is a small ground that comes out and attaches to several places inside the deck. Make sure this isnt severed or has a loose screw somewhere along the way. That should fix your problem, or give you insight to what may help.
