20 Most Recent Logitech Internet 350 USB Keyboard Questions & Answers
hello, just so you know that the keyboard does not go to sleep, but to answer your question; the problem is within the control panel>power options, check the settings for your system and see what options are there for the computer to go to sleep other than that try a different port on your computer, let me know the outcome.
Logitech... | Answered on Dec 18, 2017
i have seen some keyboards not work with the usb to serial adapters. try a different keyboard. possibly the oldest one you can find.
Logitech... | Answered on Oct 03, 2017
Make your day easier-order a $30 replacement from Staples.
Logitech... | Answered on Jul 16, 2014
0000
Logitech... | Answered on Mar 03, 2014
Hi, I had a similar problem with a microsoft usb (wired) optical mouse. I shut down my computer and pulled out the usb cord. Mine has four thin rubber pads on the bottom. I removed the two farthest from the usb cord, and underneath each were two screws. I removed those, and then was able to carefully open up the mouse. Inside I found a small chunk of black plastic, that possibly broke off of something. I dumped that out. The usb cord plugs into the circuit board inside through a connector. I partially pulled the connector out of the board, then re-seated it. I also blew puffs of air into the optic (probably an LED). I cleaned the scroll wheel with a Q-tip dipped in alcohol, and cleaned anything else that needed it with a Q-tip and alchol as well. I reassembled it with the screws, stuck the pads back on (still sticky), plugged it back in and booted up my PC again. Now it is working very well if I use it on a black 3-ring binder (not a floppy one, a hard one). I don't know which thing I did was the trick, but it might help you or others. It still doesn't work well on white (paper for example). The connector may have gotten loose, or the plastic chunk may have been blocking the optics.
Logitech... | Answered on Sep 28, 2013
You turned on Verr. Maj. by hitting [ctrl] [shift]. Hit it again once or twice to turn it off. Normal = ?, then [ctrl] [shift] = ?
Logitech... | Answered on Dec 06, 2012
If you go to logitech.com you can look up your product and they will give you a list of any software that goes with your keyboard to download.
Logitech... | Answered on Feb 24, 2011
I do not have any Owners manuals, only foll service manuals. If you have a specific question, contact me at [email protected] and I will help you with whatever you need. I will be publishing articles in the near future about how to charge batteries, etc.
Logitech... | Answered on Apr 22, 2010
Hi , Just clip the key back in where its supose to, the clip should fit rite back in , i take my keys out often to clean them...
Hope you come right ,
happy new year
Logitech... | Answered on Jan 04, 2010
Take it to company and change it.
Logitech... | Answered on Dec 16, 2009
where my inbox
Logitech... | Answered on Dec 14, 2009
problem might be with your key board...but you can disable rotation in monitor display properties
Logitech... | Answered on Oct 01, 2009
Most likely it's a programming thing but it could be you have a loose wire... Never no.. Mite try getting a cheap pair try to see if the same problem occurs.. Thanks good luck
Logitech... | Answered on Sep 10, 2019
at Logitech.com
no keyboard model stated so generic answered.
all wireless kbd need a battery , to transmit the radio signals for BT or wifi or for custom kby tech.
pair to what, no PC stated. we can not guess what you have there. at all.
Logitech... | Answered on Jun 30, 2019
They usually just snap in by pressing.
Logitech... | Answered on May 09, 2019
Have you tried the Logitech site/? Or maybe Google??
Logitech... | Answered on May 07, 2019
Logitech Internet 350 USB Keyboard Logo
23 questions posted
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
network computer doesnt see keyboard
  • Computers & Internet
