20 Most Recent
DeLonghi EO1238 Toaster Oven with Convection Cooking Questions & Answers
I need to replace the
Toaster Ovens are purposely not meant to be repaired. Fire hazard.
Sorry for the bad news, Norm. Do as I do - take out your frustrations with it with a sledgehammer. Even then, you will find it hard to crack open.
Spring in door
I have the same problem. The end broke off. I heated the end with a torch and bent a new loop (cooled it in cold water). I hope it will work for a while. I could find a replacement on the internet. To get to the spring, just remove the left side panel (3 screws)
Light and oven does not turn on.
:-) Same here, in the middle of cooking the toaster just died. O' well, i am a tech! i opened the unit and diagnosed the problem. the unit has a non-resettable high limit thermostat that blows open when reaching high temperature. the problem is that when it happened, the oven wasn't even hot and was only on for a bout five (5) minutes. From my experience, it is due to a design defect. from all i have seen so far, it doesn't seem that the company cares about its reputation or customers... what can you expect from the French?!
BOTTOM ELEMENT DOES NOT WORK
If the top element is working, then it is either the element, the wiring harness , or the control board.
Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
The heating element must be removed and tested using a multimeter.
The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
If the element has continuity, test the wiring harness, then replace wiring harness or control board.
All the test must be done by a trained repairer, strictly observing all health and safety rules.
Regards.
Toaster overn stopped lighting/heating
They really don't make these to be able to repair....but, if you want to open it up there will be a 'thermal fuse' that has blown. More than likely you can go to Radio Shack and find one to replace it. It doesn't have to be the same 'temperature rating' but try for close as possible. Here is a photo of one;
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/craig_3fa289bf857b1a3c
No power.
There is usually a thermal fuse in line with the power wire. Check for one inside a teflon mesh wire in line with the power. Inside of the toaster over of course.
Have delonghi convection oven model A52870B that
Hi, if the the toaster already quit, that could be probably the fuse that got busted on your Oven. you can check with any local technician in your area to see on how you can get it changed.
Thank you for using Fixya.
My mom needs the manual
Hi there.
Owner's Manual for your Mom's Delonghi EO-2058 can be downloaded at http://www.delonghiusa.com
Regards.
