20 Most Recent
XO Vision GX1042 10.4 in. Car Monitor Questions & Answers
I have a zicom dvd
Hello.
On the remote control for the unit, under settings there should be a option to flip the screen the correct way. If not simply try pushing the Up, Down, Left or Right Buttons on the remote to see if that will change it.
This unit comes with very little English instructions and most of the features are not very well explained.
This feature can be used when setting up reversing camera's to the screen, some reverse camera's do not have the option to flip the picture the correct way, so Zicom give you the option from the setup menu.
I hope this points you in the right direction
Regards
GM
DVD in Mercury Monterey will not power up
All can be fixed if the electrical system is properly checked and rewired where the wires are about to give up. The DVD will work, just check its power supply and the fuse. Finally have all the sensors and electrical checked by the computer in the service station for calibrating the correct codes and double-check..............sodeep
Lost the remote
that one is easy just press menu the channel button up till you get to av1 or av2 then press the volume to change it.
WONT PLAY DVD
Try cleaning the discs, or check the inside of the DVD player.
How do i connect my head phones
These are strange headphones. They work on infra-red wireless rather than Bluetooth so the device you are playing from needs a wireless transmitter.
- Compatible with IR transmitters for wireless audio playback
- On/off switch and volume control
- Extra foam cushioning and adjustable headband for comfortable fit
- Fits any size head, even children
- Foldable earcup design provides convenient storage options
https://www.google.com/search?q=xo+vision+head+phones
