20 Most Recent
Adcraft DF-6L/2 Deep Fryer Questions & Answers
I have a Adcraft DF-6L and it was not cleaned as
After cleaning fryers for 25 years, I always revert back to EasyOff oven cleaner. Be very careful when you try to scrub or scrape the elements. There are two thermostat cap tubes. If either one is damaged the fryer won't work. The cap tubes have a small charge of gas which expands and contracts to tell the thermostat when to come on and go off. You probably can't get them perfectly clean. Start by putting water in the fryer pan and letting it boil for a few minutes. Pour the water out and if it was really greasy, boil it again. When you have floated most of the grease that will melt away, then spray the elements with the EasyOff, or store brand oven cleaner. Let it stand for 30 minutes and then rewet the element and scrub carefully with a good stiff nylon bristle brush. A steel brush might damage the cap tubes. Rinse completely clean before using the fryer.
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
