20 Most Recent Electrolux ICON Designer E30SO75ESS Oven Questions & Answers
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Electrolux ICON ... | Answered on Mar 31, 2019
check gas pressure and burn tubes
Electrolux ICON ... | Answered on Jan 07, 2018
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Electrolux ICON ... | Answered on Mar 25, 2017
well first it doesn't matter when the problem occurred warranty is warranty but you can pull the oven out and pull the panel off the top where the eoc is and pull the mylar ribbon out there is a black plastic piece at the base of the ribbon pull it up and pull the ribbon out clean it with a pencil eraser then reseat it and lock it down if that doesn't fix it then the eoc must be replaced go to www.frigidaire.com and find a service in your area it will be a warranty issue
Electrolux ICON ... | Answered on Jun 29, 2016
Good Morning Friend,
I understand you are unable to self-clean your Electrolux Icon range, model# E30SO75ESS, due to it stating "Remove Racks", when you already have. Please follow these instructions for cleaning your oven:
1. Remove the turntable from the oven before the Refresh Cycle. No food should be in the oven.
2. The Refresh Cycle is 30 minutes.
3. During the Refresh Cycle some smoke and odor may occur. Open a window or use the ventilation fan in the room.
If this does not help, I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try the "Refresh cycle". I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Electrolux ICON ... | Answered on Apr 10, 2016
separate the 2 halves and then fix the screw careful of the glass and put the parts back together .
Electrolux ICON ... | Answered on Nov 24, 2015
On the E30EW85ESP3 model I had to pull the racks "and" the supports mounted on the side walls. Otherwise it would not allow the clean cycle to begin. Hope this helps.
Electrolux ICON ... | Answered on Feb 21, 2015
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Electrolux ICON ... | Answered on Jan 05, 2015
I understand you are trying to remove the door on your Electrolux Icon oven, model# E30SO75ESS. Being, that this particular model is a microwave as well as an oven, I suggest contacting your local authorized technician. They have been trained on this particular model and will be able to assist the best. Hope this is helpful.
-Best Regards-
WP
Electrolux ICON ... | Answered on Jun 02, 2014
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
Electrolux ICON ... | Answered on May 21, 2014
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
Electrolux ICON ... | Answered on Apr 19, 2014
This is quite tricky to explain, did you lock hinge before removal, if so then should be easy to put back in.
It is very difficult to unlock hinge once taken from oven and can potentially destroy door glass if you try!
You can try to unlock but will need some pump pliers, but best not to try unless experienced
How do take the door off of my oven for cleaning from Appliance...
Warmest regards
Richard The Repairman
Electrolux ICON ... | Answered on Mar 31, 2014
Electrolux ICON  Designer E30SO75ESS Oven Logo
96 questions posted
Top Electrolux Ovens Experts
Steve Allison
Steve Allison
jdthefixer
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Ovens
  • Electrolux Ovens
Most Popular Question
electrolux icon oven self clean remove
  • Ovens
