20 Most Recent Sirius SIR-STRC1 Satellite Radio Receiver Questions & Answers
2answers
Acquiring signal
Even with the antenna looking like it is in good shape, it still may be the problem here. Physical damage may not be present, but there could be electrical damage (power surge) or corrosion on the antenna if it is in a moist environment. A quick trip to a local stereo shop can confirm this as new antenna can be plugged in to the unit to test. Also, the problem is more evident when the antenna is mounted inside the vehicle. For best reception, it is recommended that the antenna be mounted to the exterior of the vehicle and have a clear view of the sky. Make sure that there is plenty of metal underneath the antenna and you should be fine.
9/8/2008 12:35:16 AM • Sirius SIR-STRC1... • Answered on Sep 08, 2008
I have a Sirius Starmate ST2. It's stuck on 0% updating. Any suggestions? Antenna placement a d connection seems fine
Hard Reset: Sometimes a hard reset can help. You can do this by pulling the fuse related to the Sirius system, letting it sit for a couple of minutes, and then putting it back in. Afterward, start the car, perform the Sync maintenance update, shut the car off, and then turn it back on. If you're unsure about which fuse to pull, consult your vehicle's manual or seek professional assistance. But thee following may help. Behind the glovebox. There's 2 15amp fuses on the top-righthand side. It'll be the left one of those two. Refresh the Signal: Visit the SiriusXM signal refresh page and follow the instructions to refresh your SiriusXM signal. Note that you may need to select a specific channel during this process, but if the system is stuck, this might be challenging.. Check for Memory Leaks: After disconnecting the battery, you mentioned that radio stations displayed their real frequency instead of "403" or incorrect frequencies. This suggests that there might be memory leaks in the Windows CE and Entertainment applications. Keep an eye on this behavior and consider reporting it to SiriusXM or seeking further technical support. Remember that these steps are general troubleshooting suggestions,
3/24/2024 11:45:11 PM • Sirius Audio... • Answered on Mar 24, 2024
2012 Dodge Caliber. I can't go back to FM radio with sound since I hit the satellite button by mistake.
Question edited for clarity.. When you say "Your previews have taken my sound", can I point out we are FIXYA and not Sirius, we just have a Sirius Category for handy filing. No one from Sirius is here. Your Radio and Media is very complex and has far too many buttons! The information starts in 227 of 506 on the top heading, written as Page 225 in the document. You are looking to change 'Mode'. The instructions should make more sense to you than me, especially if you can grab a cold drink and sit in front of it as you are reading. https://cdn.dealereprocess.org/cdn/servicemanuals/dodge/2012-caliber.pdf ..
6/25/2022 3:48:07 PM • Sirius Audio... • Answered on Jun 25, 2022
3answers
HOW DO I FIND OUT WHAT SIRIUS XM ACCOUNT I AM BEING CHARGED FOR?
First look on your credit card statement. If that doesn’t help then get the ID from your Sirius device and compare to statement. Lastly call them with the ID. If you have multiple Devices, then any device that can receive channels is being billed somewhere....
6/18/2022 2:36:55 PM • Sirius Audio... • Answered on Jun 18, 2022
2006 Bentley Flying Spur. How do I get or find the radio number off of it? VIN SCBBR53W76C033311
Question edited for clarity and typos. The Serial Number is on a sticker on the back or side of the radio. A radio / alarm installer might be able to get the serial number by using a pro grade scan tool computer.
5/13/2022 4:33:37 AM • Sirius Audio... • Answered on May 13, 2022
I can't login to Sirius radio because I changed my password and I can't edit it on the onkyo tx 8140
Sign in online and manage it from there.
Manage Your SiriusXM Account - Sign In, Convert ...
https://care.siriusxm.ca What Is SiriusXM? What's on · Plans · Listen · Shop. Sign in to manage my account. The Username and/or Password you entered does not match our records. Register your account · ‎SiriusXM Streaming · ‎Contact Customer Care · ‎Help
12/8/2021 2:44:12 AM • Sirius Audio... • Answered on Dec 08, 2021
Kia Soul 2018 No Signal on Sirius XM
pay for subscription
9/3/2021 12:11:09 PM • Sirius Audio... • Answered on Sep 03, 2021
Recover sirius stiletto2
that is a satellite radio that you have to pay for monthly or annually fixya has no information on that system
5/6/2021 7:12:13 AM • Sirius Audio... • Answered on May 06, 2021
2011 ford fusion radio works. Can get stations in urban areas when I get outside those areas lose stations. If I try the Sirius it tells me antenna fault. Can an antenna go bad.
possible bad ground or connection on regular antenna on serius make sure antenna is there some radios come with the option but no antenna
11/1/2020 4:29:39 AM • Sirius Audio... • Answered on Nov 01, 2020
0answers
2007DodgeRam Sirius radio problems. Start truck,radio pauses,change channel goes to ch 254 then 2, stays stuck. Screeching through speakers when put in drive. changed stereostockdidn't fix Antenna?
I read a response on a different website where the guy having a similar problem took the car to his mechanic and they changed the antenna.
Another fellow said he solved this similar problem by doing a system reset. After the reset, he downloaded all of the system updates and reset the presets, etc. About 4 hours total but it did fix the problem.
6/17/2019 4:22:23 AM • Sirius Audio... • Answered on Jun 17, 2019
I have a lifetime subscription for Sirius, I can’t find my info,I would like to have Sirius again,, can you find my info for me?
You will need to contact Sirius Customer service at 866-635-5027. They will have z record of you on file.
Note that some of the "lifetime contracts" only applied to the vehicle it was originally issued to.
6/12/2019 7:34:33 PM • Sirius Audio... • Answered on Jun 12, 2019
Radio Sirius Sat AM FM intermitin plays for 2 seconds off for 4seconds &repeat
Method to troubleshoot Sirus intermittent connection.
https://www.vaistech.com/satellite-radio-cutting-out/
6/8/2019 5:19:14 AM • Sirius Audio... • Answered on Jun 08, 2019
I have an aftermarket Clarion NX501 in my 2010 Camaro. If I want to add Sirius XM programming, do I use the original radio number on the VIN or is there a NEW radio number that Links to the NX501?
Any numbers on the car's VIN are related to factory fitted equipment only. To receive Sirius Satellite Radio on the NX501, you can connect the optional SC-C1 Sirius Connect Universal Vehicle Tuner 607SCC1 directly to the head unit's Sirius direct connection (no proprietary interface required), although this is no longer available, or try https://www.sonicelectronix.com/item_91789_SiriusXM-SXV300v1-70-Rebate-3-Months-FREE.html
5/27/2019 5:15:13 PM • Sirius Audio... • Answered on May 27, 2019
Sirius SIR-STRC1 Satellite Radio Receiver Logo
1 questions posted
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sirius Audio Players & Recorders
Most Popular Question
acquiring signal
  • Audio Players & Recorders
