20 Most Recent
Stanton STR8-60 Turntable Questions & Answers
My srt8 60 right output go up and down how can i repair
Well seems to me like your tone arm ain't new anymore f. But first we clean the and record and level it and check for movement on the tonearm , if it does, repair it annd if it's a lot, replace the arm
And know we start to test the needle
Turntable speed
well maybe your z35 switch is dead?...... Hehe you have done everything besides looking at the problem:)
The turntable is like stuck or something. It was
If the motor is working you need to remove the plater and check the center bearing it might sunk or got stuck for some reason. The lube might dried out, and the hard ball bearing had worn into the soft brass that the tube was made from. Relubing, and replacing the ball bearing with one of a larger diameter, can cure the problem.
Hi, I've had a pair of these awesome decks for
sounds like dodgy internal cabling u need a volt meter to check between cartrigde and main outs also have you checked if you have an output from cartrigde on both channels you will need to swap leads on bak ov cartridge itself but b carefull pins are delicate
I hooked up my new stanton t-60 turntable to an
Are you using the phono input on the Sony? If so, you're getting too much gain, you've already got a phono pre amp in the Behringer. Try using the tape or C.D. input. That should solve it.
My Stanton STR 8-60 just
Hi
Thanks for using FixYa. If it does not have power at all then please check the power cable and try using another power cable. Also check all the cables coming and leaving the Stanton STR 8-60 Turntable. Many turntables need to be earthed to a pin of the back of the amplifier. Kindly make sure the Truntable is grounded and the Pre-amp connection is firmly connected. Please do let me know if you are using the Turntable with the PC.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
STR8-60 stylus
I suggest you contact the MUSONIC web site. They specialise in cartridges and styli.
No power cable
There is no polarisation on the input lead - It won't hurt the deck if you get it reversed. If you have a shaver lead that fits, that should be fine.
Matt
My Stanton STR8-60 is not tuned correctly. I need help trying to get it to hold the right rpm for the platter.
You know it isn't for playing records. It is made for DJ Scratching from the 1980s.
Str8-60, any facts of info?
Vinyl Engine
https://www.vinylengine.com > viewtopic
Feb 18, 2012 - The s
tr8-60 is the bottom of the line dl deck from stanton, and has straight tonearm. it is
designed for dj use and is not really suitable for ...
AT150MLX on Stanton STR8-60? - Vinyl Engine
May 25, 2016
Ground wire repair on Stanton STR8-60 - Vinyl Engine
May 5, 2021
Stanton STR8-60 Replacement Power Cable - Vinyl Engine
1 post
Apr 18, 2021
Picking a cartridge with a turntable with no anti-skating
Mar 31, 2015
More results from www.vinylengine.com
stanton str8-60 : r/turntables
Reddit · r/turntables
2 comments · 9 months ago
The
STR8 turntables have a totally straight tonearm designed for DJ "scratching". If you just want to listen to records, they're not good ...
$50 Stanton STR8-60 got picked up today; all it needed was a ...
May 20, 2021
Stanton STR8 any good? : r/vinyl - Reddit
Oct 29, 2015
Stanton turntable model str8-50 vs. AT LP-60? - Reddit
Nov 13, 2023
Two Stanton T.60's and a M.202 mixer for $150? : r/DJs - Reddit
Jan 11, 2019
More results from www.reddit.com
