20 Most Recent Sony MHC-LX1000 Shelf System Questions & Answers
This is for model # MHC-LX10000. All of these answers are WRONG ! Do not listen to these. Its very simple, I had the same problem happen to me today and simply reset the system to the original factory settings. Here's how to do this and is very easy. It is mentioned in the user manual on Page 32. First unplug the power cord. Then plug it back in and turn on the system with the power button on the audio system. At the same time, press 3 buttons - the square/stop, ENTER and the Power buttons. The system gets reset to factory settings and the Speaker B will disappear. You will lose all your presets but the speakers will work once again. What a relief it was to me ! You can then set up your presets again. I wonder why with all these system support techs available here and bragging about how many years they have worked for Sony, none of them could mention this simple solution.
Sony MHC-LX1000... | Answered on Jul 02, 2015
what can i do 2 fix the above question,
Sony MHC-LX1000... | Answered on Nov 13, 2013
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sony MHC-LX1000... | Answered on Apr 01, 2011
If you have an older android phone or tablet, you can download an app. If not, go to any electrical or department store and buy a universal remote. You can also look on Ebay and Amazon
Sony Audio... | Answered 22 hours ago
Yes, sometimes that is the only way. There is a reading lens and a tracking lens. Also make sure you discs are clean and not scratched. You can clean with acrylic polish.
Sony Audio... | Answered on May 14, 2019
Hi Humberto, comment the brand and model of the phono preamplifier, also if it has a separate power supply or inside the preamplifier cabinet
I ask you this, because if you were armed in a plastic cabinet, you could pick up interference caused by cell phones or other type of component that can emit electrical noise and these interferences are those that could generate the noises that you hear in your speakers at the moment that you listen to the discs
I await your comment
Greetings Franco Dosil
Hola Humberto, comenta la marca y modelo del pre amplificador de fono, tambi?n si tiene fuente de alimentaci?n separada o dentro del gabinete del pre amplificador
Te pregunto esto, porque si estuviera armado en un gabinete pl?stico, se podr?an captar interferencia que producen los tel?fonos celulares u otro tipo de componente que pueda emitir ruidos el?ctricos y estas interferencias son las que podr?an generar los ruidos que escuchas en tus parlantes en el momento que escuchas los discos
Espero tu comentario
Saludos Franco Dosil
http://diagramasde.com/diagramas/audio/Sony%20HCD-CP100.pdf
Sony Audio... | Answered on May 13, 2019
Hello, yes, supposedly you should walk, you can try without risk of something being damaged, at most it will not work
Discuss how the test was
Hola, si, supuestamente deberia andar, puedes probar sin riesgo de que se perjudique algo, a lo sumo no funcionara
Comenta como fue la prueba
Sony Audio... | Answered on May 12, 2019
Hello Giannis, the indication that appears on the screen, can be for several reasons, malfunction of cassette players, malfunction of the compactera and / or malfunction of the speaker output, in the worst case the audio output, scorched
If you have technical knowledge, you can try to disarm the equipment and go disconnecting, the flat cassette connection tape and fix if it starts, if it does not, leave disconnected and disconnect the flat tape from the compactera and the multi-legged cable that comes from the mechanism of the compactera, try again, if it still continues, you should check that you do not have direct current in the output of the STK4211
Otherwise, you will have to take it to a specialized technical service
Note, in this Sony model, you can not join the speaker negatives, since they do not have the common configuration, the audio outputs are Bridge type
I hope you can solve the problem, comment the results
Hola Giannis, la indicacion que te aparece en pantalla, puede ser por varios motivos, mal funcionamiento de las cassetteras, mal funcionamiento de la compactera y/o mal funcionamiento de la salida de parlantes, en el peor de los casos la salida de audio, quemada
Si tienes conocimientos t?cnicos, puedes probar de desarmar el equipo e ir desconectando, la cinta plana de conexi?n de las cassetteras y fijarte si arranca, si no lo hace, deja desconectado y desconecta la cinta plana de la compactera y el cable de varias patas que viene del mecanismo de la compactera, prueba nuevamente, si aun continua, tendr?as que revisar que no tengas corriente continua en la salida de los STK4211
Sino, tendr?s que llevarlo a un servicio t?cnico especializado
Nota, en este modelo de Sony, no puedes unir los negativos de parlante, ya que no tienen la configuraci?n com?n, las salidas de audio son del tipo Puente
Espero que puedas resolver el problema, comenta los resultados
https://www.manualslib.com/products/Sony-Hcd-Rxd9-3282326.html
Hello Anthony, to replace the batteries, you must disassemble the pads and remove the 3 screws of the speaker cover, there will appear the batteries
You must replace with similar batteries
re-close the speaker covers, place the pads and let it charge for 12 hours, so that the load is effective
I hope you can solve your concern
Hola Anthony, para reemplazar las bater?as, deber?s desarmar las almohadillas y retirar los 3 tornillos de la tapa del parlante, ah? aparecer?n las bater?as
Debes reemplazar por bater?as similares
vuelve a cerrar las tapas de los parlantes, colocar las almohadillas y dejar cargar por 12 horas, para que la carga sea efectiva
Espero que puedas resolver tu inquietud
https://docs.sony.com/release/MDRRF985RK_EN_FR.pdf
Sony Audio... | Answered on May 11, 2019
Google (sony)(CDP-C10)(manual) without parens.
eBay has one for sale.
https://www.ebay.com/itm/Original-Owner-User-Manual-for-the-Sony-CD-C10-CD-Player-/381420354586
Beware of search results using https://www.google.com as some sites are fraudulent and malicious that pretend to have the manual online.
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
Sony Audio... | Answered on May 08, 2019
You could try cleaning the the head. It is a small square shaped box that the tape runs across. Clean with rubbing alcohol on a cotton swab
Sony Audio... | Answered on May 07, 2019
Possible dirty head. It is a small square shaped metal block that the tape runs across. Try cleaning it with rubbing alcohol on a cotton swab.
Sony MHC-LX1000 Shelf System Logo
7 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony stereo system keeps
  • Audio Players & Recorders
