20 Most Recent Denon AVR-1707 Receiver Questions & Answers
green, blue, and red for video, white and red for audio.
Denon AVR-1707... | Answered on Dec 03, 2017
hi there,
if the stereo turns back off after it turns on plese make sure that the power cord is tight and that there is no loose power connection to make sure that the electircity it receives is stable. don't forget to check the fuses as well make sure that they are in good condition.
If you're done with that you can now check the cord if it looks good or if it feels that something is cut or disconnecting which is causing the power to be gone.
If that passed then you would have to check the capacitors, resistors and Integrated Circuits (IC's) connected on the PC-Board. Use a power tester to check for continuity and check if there's a visible sign of burning or if the capacitor heads are swollen.
If there is no visible sign and the capacitors and resistors have passed the continuity test, then a very rare case would be that the pc-board has gone bad.
Hope this helps!
Denon AVR-1707... | Answered on Jul 03, 2011
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
Denon AVR-1707... | Answered on May 25, 2011
You may have toasted the amp. You cab try reseting the microprocessor by using the hard power button and the a b speaker buttons. turn the unit off using the power button. hold the a and b speaker buttons and while holding turn the unit back on. screen should flash a couple times. release a and b buttons. good luck
Denon AVR-1707... | Answered on May 24, 2011
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Denon AVR-1707... | Answered on Apr 17, 2011
HeadPhone Only, the jack is probably dirty , the dust shorts the relay and cuts the speakers out, compressed air (or a good set of lungs) directed down the headphone jack should fix it.
Denon AVR-1707... | Answered on Mar 14, 2011
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1707-Receivers-manual/id/696ci073/t/2/
How did test tones sound? Page 10
Muting should be OFF.
EXT IN should be OFF.
VCR and CDR/Tape NOT selected.
Denon AVR-1707... | Answered on Feb 16, 2011
Use the twin phono audio out on tv to twin phono audio in on Denon AVR-1707 this should work absolutely fine as long as your using an analogue input on the tv if HDMI you would need to purchase a Digitial to analogue audio converter. Hope this helps
Denon AVR-1707... | Answered on Jan 31, 2011
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Denon AVR-1707... | Answered on Jan 24, 2011
Only what you can do is to bring the receiver into repair shop. The receiver has a hardware problem.
You can repair here
Denon AVR-1707... | Answered on Jul 16, 2010
"A" (single) component cable? Really? Not composite?
The source determines the aspect ratio of the video. If you decide to change it, that's your choice but it isn't accurate. 4x3 is intended to be shown 4x3. A circle will be elongated if you stretch the image to fit the screen.
Disregarding the black bars, is the geometry of the image correct? If so, why can't you just go with it?
If you want to change how the TV treats it, you'll have to refer to the TV's manual and controls.
Denon AVR-1707... | Answered on May 06, 2010
hi
chack folowing site i hope you will get your solution if you get your solution please up-date me
http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=U2boTI-j
Denon AVR-1707... | Answered on Apr 30, 2010
Denon AVR-1707 Receiver Logo
31 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
h p only
  • Audio Players & Recorders
