On my Panasonic 52'' HDTV (PT-52KCX65) I have a real bright green spot on the screen about 6 inches...
(More)
On my Panasonic 52'' HDTV (PT-52KCX65) I have a real bright green spot on the screen about 6 inches in diameter and is about a foot from the left and centered up and down. What is t he problem and what do I have to do to get it repaired? For a while it would show up one time and maybe the next time the TV was turned on it would be gone, now it seems to be there all the time.
How do you reset lamp timer with remote given. I read they said hold volume button and halfway...
(More)
How do you reset lamp timer with remote given. I read they said hold volume button and halfway switch. Do you hold volume up button or volume down and what is a halfway switch button? Just replaced lamp today but red light is still on.
Turned on tv, no picture, no sound, even tho the green "on" light was on. Tried it again...
(More)
Turned on tv, no picture, no sound, even tho the green "on" light was on. Tried it again and now the light doesn't even come on.
My TV keeps resetting from a power on state. Goes back as if i just turned TV on for first time, 15...
(More)
My TV keeps resetting from a power on state. Goes back as if i just turned TV on for first time, 15 secs and picture is back. Tried resetting the lamp timer and that didnt help.
my panasonic pt-52lcx35 remote does not have a split or pip button. my bottom buttons are tv/vcr,...
(More)
MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A SPLIT OR PIP BUTTON. MY BOTTOM BUTTONS ARE TV/VCR, VCR/DBS CH UP,DOWN. HOW DO I RESET THE LAMP TIMER. THIS IS THE REMOTE THAT CAME WITH THE TV.
For the second time since I've had this set it will not turn on. The last time it took 24 hours...
(More)
For the second time since I've had this set it will not turn on. The last time it took 24 hours before the det would shich on again.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
