20 Most Recent
Epson GT-2500 Flatbed Scanner Questions & Answers
Line running down center of all scanned documents
If the line occurs when running documents through the document feeder and not when placing your document on the glass the problem is a dirty "**** glass". Open the document feeder and look for a thin glass that probably has white out on it. Carefully remove the whiteout with your fingernail or with a damp cloth. Good luck.
How do I get rid
Simple, clean the ADF glass that the paper passes over during a scan (not the flatbed glass itself, just the thin strip of glass at the head of the flatbed glass). A speck of dirt on the glass will appear as a line down the length of the paper.
I have the Epson GT2500
There is a speck of dirt or some such on the ADF Scan glass not the flatbed iteself. As the paper travels over the glass the speck of dirt is being seen by the scanner making a "line" appear on the entire length of the scan.
The scanner is not scanning as fast as it says its
Hello
Make sure EPSON Smart Panel is installed.
If you are using Windows XP:
Click the Events tab in your scanner's Properties dialog box and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
For Windows Me, 98, and 2000 users:
Click the Events tab in your scanner's Properties dialog box and make sure the Disable device events check box is clear. Also, make sure the desired button is selected in the Scanner events list box, and the desired application in the Send to this application list is selected.
For Mac OS X users:
When in Classic mode, the buttons are disabled. Quit Classic mode. Initially, only the user who installed the scanner software can scan using the buttons. Other users must start EPSON Scanner Monitor in the Applications folder before using the buttons for the first time. From then on, pressing a button will automatically start the application assigned to it.
I have an Epaon 2500GT Scanner ."Scanner Driver" does nt move
Please try this steps before scanning
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Scanner program issues
i think the drivers needs to be reinstalled provide me information regarding your scanner like brans and the model number
i'll provide you a link to download latest drivers
hopefully it will fix the issue or else we'll try further troubleshooting
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
