FixYa.com
Uniden BCT15 Base Scanner
All Products > Uniden > Radio Scanners
Problems with Uniden BCT15 Base Scanner?
Search inside Uniden BCT15 Base Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for Uniden BCT15 Base Scanner RSS Feed Post a New Problem
Why do I get constant noise on a...
Why do I get constant noise on a particular channel?
1 Solution
I tried charging NiMH batteries in my...
I tried charging NiMH batteries in my scanner &' the batteries appear to be expanding - what can i do?
1 Solution
uniden # bc145xl scanner
when turned on the volume ia good after about 10 or 15 minites it gets low and sounds scractchy. please help thanks
2 Solutions
mercedes e240 car radio
No error codes, the radio turns on, the preset stations work, the cd changer works, but no volume or sound. I can adjust...
1 Solution
radio shack pro 2038
i am trying to program this scanner manually and dont have any instruction can you help
1 Solution
bmw 523i wont start
when my bmw 523i auto heats up to normal temparture the car will loose power and cut out.she will not start untill the...
1 Solution
Manual
Where can I find a manual for this model scanner?
Post a Solution
View All
Unsolved Support Problems
Unsolved Problems for Uniden BCT15 Base Scanner RSS Feed Post a New Problem
BCT15
I can not use my BCT15 with Microsoft Windows Vista and the usb cable from scanner to computer. Is there a download to...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeBase
Number of Channels2500 Channels
Number of Bands31 Bands
ModesAM, FM, NFM, WFM
Dimensions
Depth6.06 in.
Height2.2 in.
Width7.24 in.
Weight3.5 lb.
Warranty
Warranty1 Year
Band Coverage
Band Coverage25 MHz - 1300 MHz
Continuous CoverageWith Continuous Coverage
Uniden Contact Information
Main support number800-297-1023
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
