FixYa.com
La Pavoni Pisa PA-35 Espresso Machine
All Products > La Pavoni > Coffee and Espresso Makers
Problems with La Pavoni Pisa PA-35 Espresso Machine?
Search inside La Pavoni Pisa PA-35 Espresso Machine Knowledgebase
Troubleshooting and Support
Solved Problems for La Pavoni Pisa PA-35 Espresso Machine RSS Feed Post a New Problem
La Pavoni PISA PA-35 Espresso
The question was in the portafiltro (the filter assembly which carries the coffee), there are two springs - a simple...
1 Solution
cleaning the "Portafiltro"
If anyone has successfully reassembled the portafiltro, do you know where the tiny spring is meant to go. I can guess...
1 Solution
lA PAVONI PISA
I have a la pavoni pisa, and have apparently blown the fuse on the power cord. I need to access the back of the machine...
2 Solutions
my krups 9000 keeps on setting off the...
krups xp9000 coffe machine, sets off the saftey switch on the house mains? was not doing this yesterday why today?...
1 Solution
saeco incanto
i have wather comming out when i select steam , can you help me tankyou andre
1 Solution
Braun Aromaster 10 coffee maker
I have a Braun Aromaster 10 cup coffee maker which is not keeping the coffee as hot as it has been. Now it is also not...
1 Solution
saeco via venezia overheat cut out
Have had my saeco via venezia in for repairs 3 x now because it overheats and trips its overheat cutout switch. Would...
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeEspresso Machine
Operation SourceElectric
Max. Power950 Watts
Max. Pump Pressure15 Bar
Technical Features
Stainless Steel BodyWith Stainless Steel Body
Water Source
Water Tank Size43.96 oz.
Water SourceRemovable
Dimensions
Depth9.45 in.
Height16.14 in.
Width11.22 in.
Weight15.43 oz.
Warranty
Warranty1 Year
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
