20 Most Recent
Shuttle XPC SK22G2 Barebone Questions & Answers
We have the Samsung ShuttleX
Try jumping CAREFULLY the to pins of the power button for an instant to power up the PC to see is the switch is bad or use other PC switch, Or you can get a Power Supply Tester.
DOES NOT POWER ON. PLUG IN AND HIT POWER BUTTON,
sounds like a bad power supply you can test it if you have a pc power supply tester,or have it tested at your local pc store.also check to see if its still under warrenty,that way you could get the work done for free at an authorized repair center.
I'v adde 1 gig/1stick of memory to my machine an
Hello.
At this point, from what you described, the memory stick or the slot could be the problem.
First check the 2 memory sticks to be certain that they are compatible with each other - the type and speed. That could be your problem.
If OK, remove both memory sticks and try the second stick of memory in the first slot. If it works, the 2nd memory slot is problematic.
If it doesn't work, your 2nd stick of memory is bad and needs to be replaced.
If the memory slot is bad, there really is not much you can do except replace your motherboard.
Hope this helps.
Why would my shuttle barebones upon turning it on
Reinstall your Windows program, try buying a solid state hard drive and put your Window program on it alone usually a 120gb or 200gb will do, and have another hard drive for all your other downloads, ever since i did that my Windows loads much faster and have no hang ups or errors..
Lnstall ubuntu free
Just download the Distro you want to run and either run as a "Live" operating system ( it runs from the disk without being installed to your hard drive) or just carry out a normal install from CD or DVD. It couldn't be more simple. There are easy instructions on the disc. Good luck with your new OS. Welcome to the world of Open Source Operating Systems.
