20 Most Recent Sony CDX-GT610Ui CD Player Questions & Answers
hi marco, the problem seems with the switches on the face. make sure that ALL switches have a "click" sound when pressed down. if not then that switch needs to be replaced. faulty switches can cause the face functions to work erratically. to try another route use your unit with the wireless remote control to check if all functions work well. cheers.
Sony CDX-GT610Ui... | Answered on Sep 08, 2013
cd reset can be one of two things, its either a complete memory reset, or its a cd text reset.
some players have both included in the same button. PS. check for loose ground and power wires, as this problem may short out the entire player.
good luck
Sony CDX-GT610Ui... | Answered on Dec 30, 2010
For future reference, the manual can be found at this link
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT610UI
On page 10 of the manual, the controls for mass storage device playback are as follows:
3 (REP)
4 (SHUF)
Press 3 or 4 repeatebly until the proper selection is displayed.
You can select Repeat Track or Album with 3.
You can select Shuffle Album or Device with 4.
To turn off the repeat or shuffle, click the appropriate button (3) or (4) until Off appears then the songs are played in the order they are found on the device.
Sony CDX-GT610Ui... | Answered on Dec 21, 2010
instead of used the blue wire on the Sony head unit to the car wiring harness use the blue/whit wire
  • Blue - powers on only when am/fm is active
  • Blue/White - powers on when when radio is on am/fm/cd/ ect.
Sony CDX-GT610Ui... | Answered on Jun 15, 2010
Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Sony Car Audio &... | Answered on Jun 09, 2019
No longer listed for sale as it is old. $40 used.
https://picclick.com/Sony-Marine-Stereo-Cd-Receiver-Deck-Cdx-M501P-183497958733.html
look at Jenson Marine instead. I have one on a Boston Whaler.
https://www.jensenmarinedirect.com/
Sony Car Audio &... | Answered on May 12, 2019
+ to battery, - to ground metal in the car location where you're installing and rem to blue on back of radio.
Sony Car Audio &... | Answered on Apr 16, 2019
I'm pretty sure it means that you have to much mucis downloaded
Sony Car Audio &... | Answered on Apr 04, 2019
If it ain't turn on at all check your fuse box. It could he a fuse under hood in car under dash. If the fuse is good then pull the radio out. Do a smell test on it. If you don't smell anything suspicous then check your red yellow and ground wire. Yellow being your switched 12v which turns off and on with ignition. Check red wire also. Also ground wire is very important.if none of those work it will need to be replaced. Check fuses carefully. A blown fuse can sometimes be easily missed
Sony Car Audio &... | Answered on Apr 02, 2019
Sony CDX-GT610Ui CD Player Logo
11 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
cdx gt610ui song
  • Car Audio & Video
