FixYa.com
Onkyo CS-315 Shelf System
All Products > Onkyo > Audio Shelf Systems
Problems with Onkyo CS-315 Shelf System?
Search inside Onkyo CS-315 Shelf System Knowledgebase
Troubleshooting and Support
Solved Problems for Onkyo CS-315 Shelf System RSS Feed Post a New Problem
Tape Deck
Tape deck clicks off won't play. Slows down and stops when rewinding.
1 Solution
wont turn on
the standby red light is on my stereo but there is no display. now when i press the power button to turn it on a low...
1 Solution
repair
i try to switch my denon hifi on it goes from red to green to amber to red and does not power up
1 Solution
Malfunctioning Pioneer XC-IS21t
Hello, I have a Pioneer XC-IS21T and haven't used it for a few years.  I went to use it yesterday and in does not...
2 Solutions
driver belt
How do I put the driver belt back on? The turntable wouldn't turn so I took it off and the belt was just laying in...
1 Solution
better fm reception
Is there a way to increase the radio reception of the machine. The antenna is just a thin wire. Can I connect this wire...
1 Solution
SA AK57
I have this system and when it works it works well. However, I am having some strange problems with it that I cannt seem...
2 Solutions
View All
Unsolved Support Problems
Unsolved Problems for Onkyo CS-315 Shelf System RSS Feed Post a New Problem
ca,t listen to CD's once installed.
once i've inserted a cd - the display indicates that it's reading - you can hear the whirring noise of the cd rotating...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Number of Discs1
FunctionsCD Player · Radio Tuner
Output Power70 Watt
Sound TypeStereo
Dimensions
Depth13.88 in.
Height11.44 in.
Width21.19 in.
Weight26.5 lb.
Amplifier / Speakers
Woofer Size5.13 in.
Amplifier FeaturesBass Reflex Speaker System
Speaker Bands2 Way
Tape Deck
Tape DeckWithout Tape Deck
Tuner
Tuner TypeDigital Tuner
Tuner Presets40
Tuner BandsAM · FM
CD Player
Playable Disk TypesCD-R · CD (Audio)
Playable File FormatsMP3
Playback ModesRepeat One · Repeat All · Random
Onkyo Contact Information
Main support number201-785-2600
Support FAX201-785-2650
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
