Zoom Handy Recorder- H4
Problems with Zoom Handy Recorder- H4?
Troubleshooting and Support
Solved Problems for Zoom Handy Recorder- H4 RSS Feed Post a New Problem
zoom H-4
Hi Dropped my Zoom H4 And now it wont work on battery power it will only work with the power adaptor or usb where can i...
1 Solution
Zoom H2 handy recorder
when I switch it on nothing happens. I think it may have been damaged by a power surge. Can I have it repaired? I have...
1 Solution
Zoom H4 Recorder Says, "Card...
My Zoom H4 Digital Recorder says that my memory card is full, however I'm sure it isn't because I erased all recorded...
2 Solutions
h4 randomly stops recording on cubase le
Using the H4 as an interface to record with Cubase LE, the track suddenly freezes after ten to fifeen seconds or so and...
1 Solution
Clicking noise
When listen back to my recordings with headphones I get a random clicking noise. It doesn't matter if I am using the...
1 Solution
Zoom H2
The display screen is fading in and out (to black) and appears to be pressure and movement sensitive
1 Solution
Distortion when recording flute on cubase
I'm getting distortion when recording my flute, if I lower the gain it won't improve, it happens when I play the higher...
1 Solution
Unsolved Support Problems
Unsolved Problems for Zoom Handy Recorder- H4 RSS Feed Post a New Problem
Plug in AC Adapter - H4 goes into 'Connect...
When I work off of battery power the H4 works perfectly. When I have the AC adapter plugged in the H4 menu screen goes...
Post a Solution
Connecting / Mac / Tiger / Midi
I connected the H4 to my Mac using OS 10.4.11 (I understand there is a usb conflict for 10.5 but I'm still on 10.4) The...
Post a Solution
Is there any battery life indication?
Maybe I missed it in the manual, but I cannot find any way to see if the battery is getting low.
Post a Solution
Left internal mic level is lower than...
I noticed this a few weeks ago when editing some recordings. The left channel mic level is recording lower than the...
Post a Solution
cannot connect to PC
Hi, I had connected my Zoom to my computer via USB and when I tried to delete the files by dragging them to the trash on...
Post a Solution
Mac OS 10.4.11 does not recognize the Zoom...
My MacBook Pro with Mac OS 10.4.11 does not recognize the Zoom H4 recorder and I need to move the sound files from the...
Post a Solution
Zoom H4 recording
first when i plugged my bass into the zoom it recorded fine then i put the guitar in after on 4 track mode to rcord over...
Post a Solution
Tips & Tricks
Post a New Tip
JOG DIAL PROBLEM - Written by vezman
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Zoom Contact Information
Main support number561-997-9686
Support FAX(561) 997-2163
Sponsored Links
Loading problems.
Top Experts
Ask Me
Abrsvcs Guru
1 solutions
Ask Me
joseph915 Master
4 solutions
Ask Me
MakikiChr Wiz
2 solutions
Repair Service
Find Voice Recorder and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
