20 Most Recent ButtKicker BKA1000-4A Amplifier Questions & Answers
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
ButtKicker... | Answered on Apr 12, 2013
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
ButtKicker... | Answered on Apr 02, 2010
It will be something to do with either the sound settings on the Tablet or the same on the TV, maybe even both!
Audio Players &... | Answered 11 hours ago
For HG8546M,one cable is enough, the GPON is using WDM technology, which only require one cable.
Audio Players &... | Answered Yesterday
Just check well. Look to see a headphone sign. In this case you will use a stereo to rca jack pin. You can also ask more here http://electronicsquestionsanswered.com/
ButtKicker BKA1000-4A Amplifier Logo
11 questions posted
Top ButtKicker Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a ButtKicker Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • ButtKicker Audio Players & Recorders
Most Popular Question
keeps blowing fuse inside unit
  • Audio Players & Recorders
