20 Most Recent Sylvania 6432GG 32" TV Questions & Answers
Okay here's how you do it. Sadly they buried this DEEP in the user guide and I stumbled across it -
Press the TV Menu button then with the < or > arrows scroll to the Channel menu. From there you can select the auto scan.
Sylvania 6432GG... | Answered on Mar 16, 2019
Could be a failing power supply
Sylvania 6432GG... | Answered on Jan 16, 2018
The only inputs tho the TV are cable in and AUDIO / VIDEO in.
You can use 'stereo patch cords', to plug into the tv. Check with your local computer store to see if you can find adapters to plug into the computer and change to RCA jacks.
All of that means, you probably can't.
Sylvania 6432GG... | Answered on Dec 16, 2014
Depending on your comfort level and soldering skills this is fairly straightforward pull the back off the TV identity the part, buy a replacement at radio shack swap it out
Sylvania 6432GG... | Answered on Dec 13, 2014
It is possible that the fuse is damaged (if it is an automatic one). They are prone to damage after first shortened circuit. Try to plug in your tv elswhere and see if the issue repeats itself.
Sylvania 6432GG... | Answered on Apr 07, 2014
Check and replace its main system control memory IC.
Sylvania 6432GG... | Answered on Sep 23, 2013
Check it by making a hard reset. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset. If this do not help you, check and replace it system control memory IC. It is faulty. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Sylvania 6432GG... | Answered on Feb 11, 2013
Look carefully in the customer menu at all the settings available.
Sylvania 6432GG... | Answered on Dec 22, 2012
The Remote for the TV set itself should have either a input or source button on it (some call it tv/video) If you are hooked to a set with more than one set of the jacks they will be labeled video 1 or 2 etc.
simply with the remote for the tv change inputs until you either see the picture or the display matches the location you plugged into.
Sylvania 6432GG... | Answered on Dec 05, 2012
You most likely should have the TV itself on channel 3 and control the channels you want to watch straight from your dish box.
Sylvania 6432GG... | Answered on Nov 27, 2012
Might take about 4 minutes; maximum.
Sylvania 6432GG... | Answered on Aug 12, 2012
Sylvania 6432GG 32" TV Logo
64 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
replace antena o silvania tv 6432gg
  • Televison & Video
