Samsung HL-S5679W 56 in. HDTV Television
Problems with Samsung HL-S5679W 56 in. HDTV Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Samsung HL-S5679W 56 in. HDTV Television RSS Feed
View More Results for Samsung HL-S5679W 56 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Samsung HL-S5679W 56 in. HDTV Television RSS Feed
Answer
What appears to be the tint on my tv will change value dramatically. The causes a low frequency... (More)
Answer
No sound or picture on my Samsung HLS5679W. Yesterday it would come on by itself and worked fine.
Answer
there is no audio or video & no OSD when it is pluged in you can here the power relay just... (More)
Answer
All my components (dvd, surround system, cable box) work perfectly. But when I turn on my xbox 360... (More)
Answer
I need to find the diagram or codes meaning for an m11 diesel engine
Answer
Mute is not the problem and the picture is fine. The sound was working last night, but would not... (More)
Find a Manual
Samsung HL-S5679W 56 in. HDTV Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Samsung HL-S5679W 56 in. HDTV Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Samsung HL-S5679W 56 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Samsung HL-S5679W 56 in. HDTV Television
Key Features
Screen Size
56 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated.
Projector Technology
DLP
Display Resolution
1920 x 1080 pixels
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Dimensions
Depth
15.3 in.
Height
37.9 in.
Width
52.4 in.
Weight
9.05 lb.
Warranty
Tube Warranty
1 Year
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Composite x 1 · RF x 1 · Audio (Mini Jack) x 1 · Component x 2 · S-Video x 2 · Composite x 2 · HDMI x 1 · USB Port
Front Input Connectors
Composite x 1
Rear Output Connectors
Audio (RCA) x 1
Display Capabilities
Aspect Ratio
4:3 · 4:3 Enhanced
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Universal
Illuminated Remote
Non-Illuminated
Audio Features
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Screen Text
Closed Caption on Mute
Without Closed Caption On Mute
Image Quality
Comb Filter
Analog 3-Line
Adjustable Color Temp.
With Adjustable Color Temperature
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Samsung Contact Information
Main support number1-800-SAMSUNG
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
