Mitsubishi WD-65732 65 in. HDTV Television
Problems with Mitsubishi WD-65732 65 in. HDTV Television?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WD-65732 65 in. HDTV...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi WD-65732 65 in. HDTV Television RSS Feed
View More Results for Mitsubishi WD-65732 65 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WD-65732 65 in. HDTV Television RSS Feed
Answer
i have a mitsubishi wd-65732 and i need the whole screen to be replaced and the bulb, how much will... (More)
Answer
am aware of the connector problem on the sensor(i.e. airway blocked message and shut down) .What... (More)
Answer
I would like to know how to safely remove the front of my television & clean the mirror due... (More)
Answer
Prior problems with lamp would have the lamp indicator light go red. This time, the status light is... (More)
Answer
Any available repair how-to info on replacing/soldering capacitors on DM Board for a Mitsubishi... (More)
Answer
where is the convergence setting, and focus button on a mitsubishi wd-65732, so I can try to change... (More)
Find a Manual
Mitsubishi WD-65732 65 in. HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WD-65732 65 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Mitsubishi WD-65732 65 in. HDTV Television
Owners Recommend
out of 3
Reliability
Ease of use
Value for Money
Top reviews for the Mitsubishi WD-65732 65 in. HDTV Television
georgie811
georgie811 wrote:
the thing was 3 years old and it crapped out! I still have a broken 55" Diamond series broken sitting in the garage!!! I...
Find a Warranty
Specifications for Mitsubishi WD-65732 65 in. HDTV Television
Key Features
Screen Size
65 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated.
Projector Technology
DLP
Display Resolution
1920 x 1080 pixels
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Dimensions
Depth
19.81 in.
Height
40.75 in.
Width
58.5 in.
Weight
99 lb.
Warranty
Overall Warranty
30 Days
Connectors
Rear Input Connectors
S-Video x 2 · DVI x 1 · Composite x 2 · RF x 2 · Component x 3 · HDMI x 2 · FireWire x 2 · Audio (RCA) x 7 · G - Link
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Composite x 1 · Audio (RCA) x 2 · Coaxial Digital · CableCARD
Memory Card Slot
SD Card · SmartMedia Card · MMC Card · IBM Microdrive · CompactFlash Card Type I · CompactFlash Card Type II · Memory Stick · Memory Stick Pro
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Audio Features
Audio Output
Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Screen Text
OSD Languages
English · Spanish
Closed Caption on Mute
With Closed Caption On Mute
Image Quality
Adjustable Color Temp.
With Adjustable Color Temperature
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
