Sony KDS55A2000 55 in. HDTV Television
Problems with Sony KDS55A2000 55 in. HDTV Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Sony KDS55A2000 55 in. HDTV Television RSS Feed
View More Results for Sony KDS55A2000 55 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Sony KDS55A2000 55 in. HDTV Television RSS Feed
Answer
hi i have a sony kds-55a2000 tv the color is very green tried adjusting does not help what should i... (More)
Answer
I have gone thru 2 bulbs in 3 years according to Sony they should last 4 years! I make sure to... (More)
Answer
I have a sony kds 50a2000. I replaced the lamp. But the tv wont turn on. I get the 3 lights flashing... (More)
Answer
i was replacing the bulb in my sony kds60a2000 and when replacing the door I broke a small plastic... (More)
Answer
I replaced the lamp about a month ago, but now I only get a blue screen, I have DishNet Digital... (More)
Answer
I have a Sony rear projection TV, model KF50WE510. On turn on the green light blinks on ~ 6 times,... (More)
Find a Manual
Sony KDS55A2000 55 in. HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Sony KDS55A2000 55 in. HDTV Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Sony KDS55A2000 55 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Sony KDS55A2000 55 in. HDTV Television
Key Features
Screen Size
55 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated.
Projector Technology
SXRD
Display Resolution
1920 x 1080 pixels
Technical Features
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Dimensions
Depth
19 in.
Height
36 in.
Width
50.88 in.
Weight
83.78 lb.
Warranty
Overall Warranty
1 Year
Connectors
Rear Input Connectors
Audio (Mini Jack) x 1 · S-Video x 1 · Component x 2 · Composite x 2 · 1 x D-Sub (RGB PC) · Audio (RCA) x 4 · RF x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · Component x 1
Rear Output Connectors
Audio (RCA) x 1 · Optical Digital
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Multibrand
Audio Features
Audio Output
Variable / Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Surround Sound Type
Dolby Digital / AC3
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 12 Watt
Sony Contact Information
Main support number800-488-7669
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
