20 Most Recent
Insignia NS-8PDVD Questions & Answers
Why is my portable dvd player is reading no disc when disc is in?
Over time the laser pickup becomes weaker until it is unable to read a disc. Try a dvd cleaning kit and follow instructions, or get a Q-Tip and rubbing alcohol and gently clean the lens, allow several minutes to dry. If this fails cheaper to replace the player.
4/15/2012 7:48:51 PM •
Insignia...
Answered
on Apr 15, 2012
I have a 3 year old insignia 8
http://www.amazon.com/NS-7DPDVD-PD040922-PD101351-JE-A15-09V0A1-JEA1509V0A1/dp/B001R28LJ2
Link for AC Adapter.
http://rover.ebay.com/rover/1/711-67261-24966-0/2?ipn=psmain&icep_vectorid=263602&kwid=1&mtid=691&crlp=1_263602&icep_item_id=260544576977&itemid=260544576977
Link for Car Adapter
http://bestbuy.partsearch.com/Model/Best+Buy+Company+Incorporated/Insignia/NS8PDVD.aspx
Link for batteries.
You can do further searches and maybe get yourself some better prices. Good Luck!
11/27/2011 10:02:10 PM •
Insignia...
Answered
on Nov 27, 2011
Disc in system but it
I suggest to try with another disc. If that happens again, then try to clean lens with special disc. And if then won't help, then you'll need to change laser that reads discs. Usually it's not worth trying
8/30/2011 7:00:46 PM •
Insignia...
Answered
on Aug 30, 2011
Insignia NS-P8DVD not reading disc
Try a lens cleaner. Also, ensure that the disk you wish to play is clean and scratch free. Reset your player to factory defaults. If the problem persists, you may pursue service options through the place of purchase.
7/1/2010 12:58:02 PM •
Insignia...
Answered
on Jul 01, 2010
Insignia NS-8PDVD DVD player - shaking picture
Try to run a disc cleaner in it first then if that doesnt help you may have a non repairable condition as ther is no repair places for these things. You can also try a different DVD and see if that makes a difference, a store bought DVD just to confirm things arent working properly..
5/1/2010 4:05:21 PM •
Insignia...
Answered
on May 01, 2010
Player freezes constantly, new problem
Take all DVD dics that freezes,get some dish washing soap wash the DVD dics laser surfaces to clean fingers prints, grims,dusts.Should solved this problems.
3/29/2010 11:10:05 PM •
Insignia...
Answered
on Mar 29, 2010
The disc spins and I can hear the audio but the
HELLO!
There is a problem might be the screen cable which could be damaged or not seated correctly in its slot .need to be checked I recomend swapping of the cable to see its status .
If the cable is ok( mb contacts and screen) are good then swap screens your screen might be burnt or damaged .
and check the screen circutry for voltage regulator with a multimeter
it could be burnt .
Good luck
11/30/2009 3:18:52 PM •
Insignia...
Answered
on Nov 30, 2009
I have an insignia T.V. that I picked up on the
it will be a DC power supply normally so i would not plug direct in the mains.
normally there is a marking on the unit of required voltage also the white line is usually + and black -
and it could be anywhere from 12v onwards
best of luck.
8/26/2009 7:57:57 PM •
Insignia...
Answered
on Aug 26, 2009
DVD player plays 10 minutes and then freezes screen.
You may have a problem with the transport of the dvd laser. Open the compartment that you place the dvd into. You will see the spindle,the laser lens and the transport device that moves it during operation. The transport system operates on system of gears and drive rails. You must check and clean the drive rails and gears. Use a can of compressed air and blow all the dust and debris from the dvd compartment. Then use some cotton swabs with a small amount of isopropyl alcohol on the tips and clean all the rails and gears. Check the transport action by moving the transport to its most outer position and back to its most inner position. The action and travel of the transport on the rails should be smooth and easy. The gears should be clean and move easy also.These parts will require cleaning every month or so . Remember do not touch the laser lens with your hand. You should also check the lens it should look bright and shine. If not try cleaning it with a cotton swab and a small amount of alcohol. Rub the lens gently back and forth unit it is bright and shines.Now you can try playing a dvd and see if the player works properly. If this does not fix you problem. You can reset the dvd player to the factory settings.1.Press the setup button on the remote control.2.Use the left and right arrows to highlight the preferences page.3.Press enter to to enter the preferences sub-menu.4.Use the up and down arrows to find the default function and press enter. You now have reset the dvd player to factory settings Now again play a dvd to see if the player is functioning normally. If not you may have a more serious problem with the drive motor or power supply circuits. you can call Insignia customer service support at this telephone number.1-877-467-4289. Give them the model number of you dvd player and tell them the problem you are having with the loss of operation during the playing of a dvd. They will be able to tell you how to get testing and service for you dvd player. I hope this information helps you with your problem.
6/3/2009 7:35:39 PM •
Insignia...
Answered
on Jun 03, 2009
Remote
You can call Insignia customer service at this telephone number. 1-877-467-4289 Tell them the model number of you dvd player and that you would like to know how you can get a replacement remote control. You can also call this telephone number for Insignia replacements parts. 1-888-237-8289. Give them the model number of you dvd player and ask the if they have a replacement remote control in inventory and can sell you one. I hope this information helps you with your problem.
6/3/2009 6:38:27 PM •
Insignia...
Answered
on Jun 03, 2009
Unlock codes Insignia NS-8PDVD
You may have missed a step in the procedure try this one. This information was found on the following website http://www.videohelp.com/dvdhacks/insignia-ns-7dpdvd/8394 It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
6/3/2009 6:32:10 PM •
Insignia...
Answered
on Jun 03, 2009
