20 Most Recent
Yamaha DSPE390 Amplifier Questions & Answers
When I play surround sound
This may not be from your speakers. This could be caused by the disc itself or from the dubbing of the movie. Try playing a different CD entirely.
Best regards
No sound
Make sure speakers are hooked to proper connectors. Also check speaker switch "A"/ "B"/ "A+B" is positioned to correct speakers.
Also make sure mute switch is off
Power suply
Osolation?
What do you mean - isolation, or oscillation?
Carver m500
Hi, first it's not power, it's the voltage you need to know, is the transformer burt, if not you can mesure the voltage output by putting a voltmeter at the primery to see if 120vac is there and then the output to see how mutch at each two wire at orange is and then at the two red is. They should be about 24vac on orage and 60 volts at the red.
Not shure what the voltage just guessing, if totaly dead then you have a burt transformer, some of these unit have a internal fuse, you may see them on the top, they may be also thermal shutdown sensor's fuse type, look to see if there is one, if so look at there value, thermal has a degree in C for the value and pico fuse has amp's or ex 4a .
I hope this help
Bob
Home cinema
yes kilshpsh ones at best buy 299 whole set they rock or u want whole system x40 samsung very nice sound ok 199
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
