20 Most Recent HP Compaq Presario SR5010 Desktop PC (Intel Celeron D Processor 360, 512 MB RAM, 120 GB RAM, DVD Drive,... Questions & Answers
To download and install the System Update Readiness Tool, follow the steps below:
1. Click Start
Collapse the imageExpand this image
, and click Control Panel.
2. If you use Windows 7, click System and Security. If you use Windows Vista, click Security.
3. Under Windows Update, click Check for updates.
4. The System Update Readiness Tool (KB947821) is offered, only when
5. Click Install updates.
hope this helps
HP Compaq... | Answered on Jul 14, 2012
You will want to check in Device Manager to see if the device is even detected by the computer. Right Click My Computer, Properties, Click Hardware Tab and Device Manager. If it isn't recognizing the DVD drive then it is most likely bad.
HP Compaq... | Answered on Nov 30, 2011
Try to download the drivers from the below mentioned site and reinstall the sound driver.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=3328519&taskId=135
Regards,
JJ
HP Compaq... | Answered on May 15, 2011
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
HP Compaq... | Answered on Dec 11, 2010
I think that model has a max of 2gb>pc2-4200< about 20 bucks online...More memory, happier PC!!!
HP Compaq... | Answered on Apr 11, 2009
A great tool for a non destructive computer clean is tuneup utilities 2009.
If you want to wipe the machine, backup any important files, Backup your computer's drivers (if you don't have them on cd).
Then pop your windows disk in and run it, in windows, it should take you through everything. Allow about 2 hours.
Hope this helps,
Tom
HP Compaq... | Answered on Jan 29, 2009
Here is the drivers:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=3398011&lang=en
HP Compaq... | Answered on Jan 19, 2009
Hi!
Here you can find the drivers for that computer:
Try to Enable DMA in property of My Compter>hardware>device manager>Secondry IDE channel property...
HP Compaq... | Answered on Nov 29, 2008
have you try uninstall your dvd driver.. then install it again.
HP Compaq... | Answered on Mar 26, 2008
Appears that recovery disk #2 is bogus. U can try to get a new set from HP (fat chance!) or you can do a reload from a normal, retail OS disk.
HP Presario... | Answered on Jun 21, 2017
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
HP Presario... | Answered on Jan 26, 2017
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs).
A. If your computer will boot and you can operate it ok...
Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
B. If your computer won\'t boot, or can\'t operate properly after boot...
Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.
Good luck
G
HP Presario... | Answered on Jul 30, 2014
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply"
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
HP Presario... | Answered on May 13, 2014
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air.
You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
HP Presario... | Answered on Mar 04, 2014
HP Compaq Presario SR5010 Desktop PC (Intel Celeron D Processor 360, 512 MB RAM, 120 GB RAM, DVD Drive,... Logo
Popular Tags
13 questions posted
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
misssing sound drivers after system
  • Computers & Internet
