FixYa.com
GE 14.1 cu. ft. Upright Freezer FUM14DTR
All Products > GE > Freezers
Problems with GE 14.1 cu. ft. Upright Freezer FUM14DTR?
Search inside GE 14.1 cu. ft. Upright Freezer FUM14DTR Knowledgebase
Troubleshooting and Support
Solved Problems for GE 14.1 cu. ft. Upright Freezer FUM14DTR RSS Feed Post a New Problem
What is freezer burn? How can I avoid it?
1 Solution
Alarm
Why does the alarm sound continously? I have defrosted the freezer and checked that the door seal is OK. It is at the...
1 Solution
Master-Bilt Freezer doesnt cool enough
I have a Master-Bilt walk-in freezer. The temperature is supposed to be at -10 degrees. The freezer will start but shuts...
1 Solution
freezer freezing up
I have this problem, can fix it, but does my freezer keep freezing up, I have too manually unfreeze it then afterwards...
1 Solution
Kenore freezer running constantly
Freezer has been running constantly, I bought a new defrost timer. It still runs. Everything I have read says to get ice...
1 Solution
fridge not cooling
I have a 4 year old zanussi fridge/freezer,the freezer compartment is working fine, but the fridge compartment does not...
1 Solution
leak
i have a kdx 200 dirtbike , and after i ride it it leaks something out the air cleaner, i took the filter off , and...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Temperature ControlWith Temperature Control
Freezer TypeUpright
Volume14.1 cu. ft.
Defrost TypeManual Defrost
Other Features
Door LockWith Door Lock
Cabinet Shelves4
Door Shelves5
Interior LightYes
Dimensions
Overall Depth28.5 in.
Overall Height59 in.
Overall Width28 in.
Warranty
Warranty1 Year
GE Contact Information
Main support number1-800-626-2005
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
