20 Most Recent
Amana AER5725QA Electric Kitchen Range Questions & Answers
My oven will not stay on .F9 code appear whats the problem?
Hi healinghe445,
It has something to do with a motorized door if you are getting this error code F9. The most common thing that needs to be checked is the latch. If you find it faulty you will need to replace it with a new one. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Have never cleaned an oven
to be safe,just use a soapy detergent and a good little brush always use warm/hot water, as greese needs a little heat,not to hot as to burn you,you will find this will remove all greese,then dry with a clean cloth,turn oven to about 100deg c for 20 mins,and thats it.adrian,,,
We recently moved, when we got to our new house we
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
