20 Most Recent
Soundstorm SDVD-100 Car DVD Player Questions & Answers
Dvd is stuck will not
>>> Please leave feedback so I can continue helping You & Others
LOOK FOR A SMALL HOLE IN THE FRONT TO PUSH A PAPERCLIP INTO, BUT TURN THE UNIT OFF FIRST. Try pulling the car fuse out, will have stereo/radio written on fusecase.
Thanks,
Adam.
Forgot parental pass code.
With some decks you can get in using either an all 0 code or an all 9 code entered as the parental passcode.. have you disconnected it from the power supply and let it sit for a bit to see if you can clear the memory?
Put a childs dvd in asking for parental code?
There is a factory preset parental code you need to enter (unless that default code was changed). That factory code is in your user manual. In order the enter the codem, you will need the remote (number pad). The remote can be ordered through Soundstorm for $35.00 and you can download the manual from their knowledge base, just search "SDVD-100". Once you have both, just use the number pad on the remote to enter the factory parental code and the system will unlock.
Soundstorm car dvd player
This is from the soundstorm website:
If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308.
Once you have this code, you can go into the settings and change the level to whichever level you like.
Here is a break down of the levels:
Level 1 = G Rated
Level 3 = PG Rated
Level 4 = PG 13 Rated
Level 6 = PG-R Rated
Level 7 = NC-17
Level 8 = Adult
Level 0 = No Parental
Modelo sd745t radio para coche tengo problemas que el panel fron
Es posible que alguno de los switches este defectuoso y se a de haber quedado oprimido y eso causa que se bloquen todos las funciones.Por lo regular,cuando un switch esta defectoso no se siente el click al oprimirlo.
Espero que esta informacion te ayude en algo.
Gracias y suerte
