20 Most Recent Laser Jet P3005d Printer Questions & Answers
uninstall and then reinstall the driver from the manufacturers web page for your model printer and the operating system of the computer
win 7 and win xp are no longer supported by Microsoft so any driver blips are not corrected
Laser Jet P3005d... | Answered on Dec 19, 2017
59.50 indicates a main motor failure either the motor is bad or something is stopping it from turning. can be as simple as a bad toner.
turn the machine on and listen for the motor noise if you don't hear it turn the machine off remove the toner and turn it back on if you can hear the motor running youmay just have a bad cart.
hope this helps
Laser Jet P3005d... | Answered on Aug 20, 2012
59.50 ERROR
alternates with
To continue turn off then on
A main motor (M1) error has occurred. Motor
operation is verified during device power-up.
1. Turn the device off and then on.
2. Verify that nothing is hindering the main
motor. If necessary, remove all paper
trays and the print cartridge, and then
turn on the device and listen for motor
operation.
3. Verify that the main motor is connected
to connector J407 on the ECU. (See
Figure 6-9 ECU wiring on page 195.)
You might have to remove the main
cooling fan to see this connection.
4. If the message persists, replace the
motor.
Part #
RK2-1488 Main Motor
Laser Jet P3005d... | Answered on Jan 17, 2011
Hello, there is a routine built into the printer you can run from the front panel.
Select the Menu and navigate to the "Configure Device" navigate to "Print Quality" navigate to "Create Cleaning Page" The Printer will request a piece of paper to be put into the bypass tray, it will then print a page. The page will be printed with instructions on how to complete the process. I would sugguest running this this at least 2 times and then every time the toner is change. A routine of running this cleaning page should help prolong the life of the fuser, I hope this helps and answers your question.....Cheers!!
Laser Jet P3005d... | Answered on Jan 15, 2011
Yes! Of course Printers are the most difficult machinery in the hardware world. Just turn of your printer restart your computer and now once you reeboot your printer and computer it should be able to recognize your devices your printer once that happens just respond back to me Ok!
Laser Jet P3005d... | Answered on Mar 26, 2010
try unplugging it from the back, the switch might be broken.
Laser Office... | Answered on Aug 14, 2019
A fuser error is probably caused by a thermistor (detects an overheating problem). The fuser is probably best serviced by the manufacturer as an improperly serviced fuser could lead to a fire.
Laser Office... | Answered on May 30, 2019
"Error 6" indicates a common problem with LaserJet, a brand of dry electrophotographic laser printers from computer technology company Hewlett-Packard. One of such machines is the HP LaserJet 3390, an all-in-one printer that can print, copy, scan and fax documents.
Laser Office... | Answered on Apr 20, 2019
Fuser Near Life Warning-- check the user manual thats the best place for this answer
good luck
https://www.6ya.com/mrmmike
Laser Office... | Answered on Mar 02, 2019
Laser Jet P3005d Printer Logo
Popular Tags
11 questions posted
Top Laser Office Equipment & Supplies Experts
Alun Cox
Norman  J Weimar Jr
Norman J Weimar Jr
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Laser Office Equipment & Supplies
Most Popular Question
m facing problem hp
  • Office Equipment & Supplies
